Chauvet DJ FXpar 9
A fixture definition for the Chauvet DJ FXpar 9:
- Chauvet-FXpar9.qxf
- (10.39 KiB) Downloaded 71 times
This is quite wrong.
If this is the manual: https://www.chauvetdj.com/wp-content/up ... ev4_WO.pdf
then you invented the DMX modes.
There should be 23/9/6/3 channel modes, while in your file there's 22/9/6/2.
Heads in 22 channel mode are plain wrong.
Auto programs channel is wrong.
Now I need to fix it all the mess.
There are obviously two versions of the fixture. A Version with 23/9/6/3 channels and a version with 22/9/6/2. I have a device in use that shows the version 1.5 at startup. It has 22 channels.
(The additional 23rd channel of the newer version is a dimmer.)
