RGBMatrix in chaser - fade time broken? qlcplus 4.11.0
giacomo
linux 64
I've been working with a converted file, when adding a new rgbmatrix to a cue list, it was working only with a 0sec fade time - in my case the duration is infinite - after assigning a value to the fade time the rgb-matrix wasn't working anymore, setting it back to 0 it was working again.
cosmetic issue:
in the rbg-matrix editor, after adjusting the duration - or any fade - time, the corresponding tap button is constantly blinking, it's noticeable with values around 200ms.
I can upload the file if needed
regards
