Hello there,
i search for a fixture. The Device Name is:
lightmaXX LED RGB Color Bar Stripe 252x10mm LED´s DMX Wall Washer
I dont know if its the real name - here you can find it:
https://www.musicstore.de/de_DE/EUR/lig ... 004084-000
I hope somebody can help me. Is the last fixture i need...
Thank you for your help!
LightmaXX LED RGB Color Bar Stripe
- Real Name: Jan F
Hello again,
here it is.
I don't get where there are different channel modes, since the only way you can "change" the amount of used channels is on channel 1. So there is just one mode...
Validated without errors.
here it is.
- lightmaXX-LED-Color-Bar-Spot.qxf
- (4.01 KiB) Downloaded 169 times
- Real Name: Jan F
If you even find the section where you can switch the mode on the fixture itself, you might send it to lightmaXX. They don't have it in their manual apparently
- Real Name: Jan F
Well in fact according to the manual there is no way to switch the fixture itself into another mode. Just settings specific values on channel 1 set if other channels are used.
