No more audio devices in QLC+
Scully
Real Name: Jiri Bednar
Hi, I'm having a problem with the audio devices. I have 3 devices in Raspberry 3, but they do not show up in QLC +. The version is 4.11.0 GIT.
Which image are you using ?
That's clearly not my image. Please provide all the information if you want help
Scully
I have this version: qlcplus-qt5-git_4.11.0.20170507.dc48f42-0_armhf.deb. I sent a donation (15EU). I got a link to download the current version, but this version will not run at all. Fixture editor will show something, but it's also not working.
Again, you're not providing all the information needed:
1- where did you get that deb file ? That's not the name of the package I provide
2- which image are you using ? (Raspbian Wheezy, Jessie, Stretch, ??)
3- Which Qt version is installed in the image you're using ?
4-
What does this even mean ? What is not working ? What did you see ?
Scully
1. I downloaded from GIT source files and compile it (According to instructions from the web)
2. jessie 4.9.35-v7+
3.QT5
4.The QLC + version of the email will not display anything. I will run and nothing.
Thanks for your patience, I'm not a Linux expert.
Scully
Alternatively, you can connect through Teamviewer to the raspberry desktop.
Sorry but I can't give support to custom built versions. You say you're not a Linux expert but you built QLC+ from sources yourself...wow.
Qt5 is still too generic. There are like 20 versions out there.
My image has to work out of the box on a Raspberry Pi 3. If it doesn't then it means something went wrong when flashing it on the SD card. Are you sure you have properly followed the instructions ?
You should see at least the Pi boot splash screen (a colorful square on the TV) or the kernel boot messages.
Scully
I will try to reinstall raspberian, thanks so far.
Scully
I installed jessie 4.4.50-v7 + (downloaded from the official raspberry site), I installed qlc + 4.11 from the email (donation). But qlc + will not run at all. What is the installation procedure for the new system installation? What do you need to install? I'm sorry for my ignorance, but I have not found any instructions. Do I need to install qt5 again? What version of raspbian qlc + is running on?
Chapter 10 of the provided PDF
Chapter 10 of the provided PDF. Yes.
Jessie. It's written here: http://www.qlcplus.org/raspberry.html, In chapter 2 of the provided PDF, and in the name of the PDF itself.
Dude, your issue is that you refuse to read the instructions.
Therefore, my help ends here, cause this is a waste of my time.
Scully
Ah sorry, I did not look for a manual installation. Previously, just install the package. Now it's ok.
