Function to Sequence error
yokosuna
Hi *
Just to notify: QLC+_4.11.1.89
Make a new project, add 4 simple dimmers to an RG Matrix, make a function, say fill,
convert the function to a sequence.
You will notice that:
a) the fixture will not be listed in the original order (i.e. 1, 2, 3, 4)
b) the values in the fixtures will have irritating values.
Thx.
4.11.1.89 is from an experimental branch.
Does it work on 4.11.1.90 or is the issue still present ?
yokosuna
Still there ...
... and in addition, the software creates a scene and names it after the matrix group.
If I delete the scene and switch over to the function editor, qlc will crash.
It´s also true for 4.11.0 with one difference: the order of the fixtures seems
not random but reversed.
And I noticed to when I run the matrix function with 76 as dmx value, the
created sequence will use 255 as dimmer values ...
HTH, Yoko
I fixed it on GIT.
Please give version 4.11.1.100 a go
