I have the project attached. When I try to move the slider 14 on page 2, attached to a function, it simply refuse to follow the mouse position and returns to 0.
May this be a bug?
The behaviour is independant of any input/out configuration.
thank you in advance
Slider don't work??
- Real Name: Diego Fantoma
- MCMulti.qxw
- (54.64 KiB) Downloaded 55 times
It's the sub master on your first page. It controls the intensity of every element inside of the frame.
I have no idea if it is intended, that the faders snap to the percentage of the sub master or if this is a bug. I tend to say that this is also a bug, because you can snap it to maximum, and the output values jump when you move a subed fader.
