First step of a Sequence doesn't work, 2nd is ok.
gd360
Hi @ all,
I am currently working on a show and I am actually not quiet sure if it's my fault or an actual issue.
I have added several sequences and there is a strange behaviour. On some (not all) sequences the first step doens't change any DMX-Value.
The workaround for me is, that I make the first step before the actual needed one and that seems to work.
But I guess thats not a permanent solution.
I also just recognized that I have a red scene that makes a pink light and I have no clue why.
Additional Info:
The Dimmer mode of the fixtures is set to LTP
The first sequence of the show is a sequence that sets all Channels to 0.
Kind regards,
Gerhard
Hey Gerhard,
please share your workspace file and any custom fixture definitions.
Regards,
gd360
File Attached.
test.qxw
(169.37 KiB) Downloaded 243 times
