Eyourlife PAR64 - Another Generic Chineese RGBW PAR
i25773
here is a 4 pack version of the PAR:
https://www.amazon.com/Eyourlife-DMX512 ... B00KYK4YP8
The manual is a 3.5MB PDF so the PHPBB wont let me attach it.
Here's the Gist:
fixture supports either 4 or 8 channel mode
IN the menu the d001-d512 is the dmx address in 4 channel mode.
IN the menu the A001-d512 is the dmx address in 8 channel mode.
Here is what the manual says the DMX channels are:
(4 channel mode)
CH1 0~255 Red brightness adjustment;
CH2 0~255 Green brightness adjustment;
CH3 0~255 Blue brightness adjustment;
CH4 0-255 White Brightness adjustment;
Here is what the manual says the DMX channels are on amazon:
(8 channel mode)
CH1 0~255 Total control brightness adjustment;
CH2 0~255 Red brightness adjustment;
CH3 0~255 Green brightness adjustment;
CH4 0~255 Blue brightness adjustment;
CH5 0-255 White Brightness adjustment;
CH6 0~255 All flashing??speed adjust??
CH7 0~255 according"red-green-blue-red green-red blue-green blue-RGB"adjust the speed of flash
CH8 0~255 according"red-green-blue-red green-red blue-green blue-RGB"adjust the speed of Gradient
**THIS IS WRONG**
In testing, i have observed:
Channel 6 is color cycle function. manual seems to think this is ch 7
Channel 7 is strobe of current RGBW (ch2,3,4,5) color levels.
Channel 8 is the function channel, with the following possible functions:
0-50 Open CH1-CH5
51-100 color selection
101-150 gradual change
151-200 pulse change
201-250 jump change
251-255 sound activated open
the fixture def. is updated to reflect _reality_ not what the amazon seller has posted.
Eyourlife-PAR64.qxf
(3.05 KiB) Downloaded 197 times
Sorry but I don't accept chinese/ebay fixtures.
If we start adding them, we'll end up with a library with hundreds of clones of clones of clones of unknown products.
