Click & Go Gobo/Effect/Macro not updating DMX in 4.11.0
Posted: Sun Jul 02, 2017 9:59 pm
by sjames
As noted here:
viewtopic.php?f=2&t=11251#p48527
in 4.11.0 Click & Go for Gobo/Effect/Macro is not updating DMX - the image updates, but the DMX does not.
The associated slider works as expected, and updates the image & DMX. Click & Go for RGB works as expected.
Tested in 4.11.0 under Ubuntu 16.04, and in Windows 10 & 7.
Re: Click & Go Gobo/Effect/Macro not updating DMX in 4.11.0
Posted: Mon Jul 03, 2017 9:25 am
by cedric5133
I have the same problem with version 4.11.0
Posted: Mon Jul 03, 2017 5:58 pm
Confirmed
I've already fixed on GIT. Test versions availble now.
Sorry about that
Posted: Sat Aug 05, 2017 11:45 pm
by mgweber
You found RGB click and go working?
I just upgraded a Mint 64 system to 4.11 and found inconsistent behavior with click and go of an rgb fixture. I downgraded to 4.10.5b until I'm able to resolve this. Not sure if it's a bug with the slider or an issue with my custom fixture definition but it has worked until this release. I have now confirmed that the issue is also present on a win10 x64 system.
I say inconsistent because I have four series of identical sliders in level mode for different fixtures. I will see one set work and another not work. Their configuration is the same except for which fixtures in the grid they are controlling. They are all using the same fixture definition. I will need to recreate my workspace and attach my fixture definition.
