4.11.0 Chaser nested into a chaser: no fade in/out possible
maximortal
Real Name: Iro Suraci
QLC 4.11.0
a chaser nested into another chaser can not have a fade in or out time itself. (i mean a fade time into parent chaser)
if you set a fade time different than 0 it works wired : previous step do not reach 0 intensity and the chaser nested do not reach it's max intensity level
here a patch to recreate this bug.
A fix for this bug is really apreciate for thetrical use of QLC (i loved your fix for side faders into virtual console!!!) 'couse the faster way to have a "special FX" in theatre is to have the chasers nested into another (I assume the chaser as default option to run a show for a theatre play)
thanks in advance for any fix ora suggestions to how workaround on this (mine?) issue
chaser nest.qxw
(4.33 KiB) Downloaded 97 times
