Showtec QFX Mutli
noda
Manual: https://www.highlite.nl/silver.download ... _GB_V1.pdf
Not the simplest one for my first fixture, as it's a light bar with Derby/PAR/Laser/Strobe LED all-in-one :D
I did my best since some functions cannot be implemented (some channel capabilities depend on other channel values... not possible to define at the moment). Just to mention it, I used the converted Avolites .d4 file as the base and completed/fixed what's missing, since there is a lot to cover.
Hope you like it!
Showtec-QFX-Multi.qxf
(13.58 KiB) Downloaded 56 times
I'm sorry but I need to keep this on hold cause of so many channel dependencies.
We need to implement a proper handling of channel dependencies in the code, but it's gonna be quite a large change.
Plus, Avolites fixtures are copyrighted, so I don't usually accept converted fixtures.
noda
The channel dependencies are only for the simplest 3/5 dmx channels modes, which I bet not many people would use.
But I understand I you want to put it on hold, I shared if it can help someone else in the meantime.
sonozikloc
Here is the fixture of the QFX multi bar in 27 Channel mode. :D
Sincerly
Showtec-QFX-Compact-Light-FX.qxf
(7.27 KiB) Downloaded 61 times
