RGB Panels More Than 99 Pixels
Posted: Sat May 20, 2017 4:19 pm
by ethanm3
Hello. I do a lot of work controlling LEDs through QLC+, and one limitation I have found is the RGB Panels limiting at 99 pixels in width and length. If I have a line of LEDs that is longer than 99 pixels, I have to come up with creative work-arounds to split them up.
For example, I made an LED bar that has 117 pixels in it, but I had to split the mapping into pieces in order to use any RGB matrices, which was fine for more abstract effects like Plasma, but didn't work at all for the Wave or Gradient effects.
Any chance that could be expanded in QLC5?
Thanks!
Re: RGB Panels More Than 99 Pixels
Posted: Sat May 20, 2017 4:39 pm
The limit has already been increased to 999.
Give some TEST version a try.
Posted: Sun May 21, 2017 2:15 am
by ethanm3
Oh, great point, thanks! Will that be reliable enough in a production environment?
Posted: Sun May 21, 2017 8:47 am
I normally don't suggest to use a test version in production for the simple reason that they are builds taken at certain points in the development "path".
However, test versions are triggered manually, so I decide to pull the trigger when I feel a build is stable enough.
In other words: you can use them, but I suggest to test your show before the gig, in case something bad happens it will happen at home :)
Posted: Mon May 22, 2017 4:51 pm
by asm
I'am using 128 rgb led in a row, no problemo. (Raspberry pi 3, with wifi artnet)
Posted: Sat May 27, 2017 1:00 am
by ethanm3
@mcallegari or others who responded: is there a specific line of code that I could change to make sure it's just the RGB Panel limits that I'd be changing? Maybe that would make it more reliable.
Thanks!
Posted: Sat May 27, 2017 7:27 am
This is commit that contains the change: https://github.com/mcallegari/qlcplus/c ... 0d21b2R315
The max row count is now 999 (if nothing is specified max is 99, http://doc.qt.io/qt-5/qspinbox.html).
Column max is still 170.
Posted: Sun May 28, 2017 6:23 am
by ethanm3
I'll try these out. Thanks a ton!
