Can anyone help me, on how to get out of this on my raspberry pi 3
Is there a hot key to close down to a command prompt.
Cant get out on this on rpi3??
Software / image version ?
What's the output device ? A HDMI TV ? A touchscreen ? A VGA monitor with an adapter ?
Full details please. I don't have the time to ask 1000 questions to understand what you're doing.
By the way, you don't launch QLC+ with the qlcplus command. Read the documentation and you'll find out there's a script for it (/etc/init.d/qlcplus) and you need to do
sudo service qlcplus stop
sudo service qlcplus start
- Real Name: Allan Madsen
Sorry for my english.
I have run the rpi 3 on my hdmi monitor no problem.
Then i have updatet the system, with sudo apt-get update and then sudo apt-get dist-upgrade
When i reboot i get theat screen shot (just without the help screen)
I can't resize it "by usinge the button i the qlcplus"
I cant close it down.
Then when i connect to i my a tty program from my windows computer and login vil pi and raspberry.
then i write qlcplus -f resize at the command promp, its ok (but the other (startet version) still layes under the new program. And there is no "close" the qlcplus button)
and when i teminate my tty login its all gone (That i can understand)
But the rest??
Hope this helps and you understand what iam writing (I am danish)
But the rest??
Sorry i am not that good to linux and i have found that file, but i can't se how to startet it in fullscreen, and i havent changes anything at all.
I am lost, i have read all the doc i can find.
I can start i by tty to my rpi with qlcplus -f resize but not to get the rpi to do it when it reboot.
If i change this line in /ect/init.d/qlcplus
QLCPLUS_OPTS="--web --operate --overscan"
to
QLCPLUS_OPTS="--web --operate --overscan --fullscreen resize"
its starts in fullscreen.
But still no button to shut it down
to
They must have changed something with the latest Raspbian updates. Please post:
- kernel version
- the output of the command
- kernel version
uname -a
cat /proc/cpuinfo
uname -a
cat /proc/cpuinfo
Here it is.
Linux raspDMX 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux
processor : 0
model name : ARMv7 Processor rev 4 (v7l)
BogoMIPS : 38.40
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 1
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 2
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
processor : 3
BogoMIPS : 38.40
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd03
CPU revision : 4
Hardware : BCM2835
Revision : a02082
Serial : 00000000af6723d3
Thanks for the info.
Indeed kernel changed from 4.4 to 4.9 and they changed how cpuinfo is formatted too.
That's why QLC+ is not recognizing that it is running on a Raspberry Pi.
I think for now you need to stick to my image and eventually update all packages except for the Linux kernel.
This will be fixed with my next image.
Thanks, for your answer.
How log to new update?
Is there a way to make a shutdown key, in the console?
And keep up the grate work you are doing Love you program.
Just got a $0.86 usb soundcart to run on it to with mic in
- Real Name: Mayk Peter
I have got pretty much the same problem, since I did "sudo apt-get dist-upgrade".
However QLC+ uses only 1/4 of the screen (upper left corner)
Even worse: I cannot get into a terminal session any more, as the button
to exit QL+ has disappeared.
How can I start a terminal session or prevent QLC from starting up?
A new image version will be released soon, please be patient.
In the meantime don't do a package upgrade.
The image is consistent to work with the packages of the date it has been released on.
thanks for the quick answer.
Actually I found meanwhile that the "resize fullscreen" option does work,
also for the RDP session. The "--nowm" option doesn't work for me yet.
Looking forward to the next image! Thanks!
That's because it hasn't been released yet ! (you probably found it in a TEST version, right ?)The "--nowm" option doesn't work for me yet.
Anyway, that's the option that will restore QLC+ correct screen resizing in the next RPi image.
