Hi Community,
I have a strange Problem with audio playback with QLC+ (4.10.5b) on macOS Sierra (10.12.4). If I import a wave file (44.1 kHz 16bit 2 channels) in Function Manager window, the file gets detected with a Bit rate of 11kb/s (should be 1411kb/s). Also the duration is wrong. I only get noise during playback.
The file was generated with Logic 9 and plays well with itunes, vlc. I also checked the metadata with bwfmetaedit. Everything is fine. Then I used ffmpeg on linux, to extract raw pcm data and generated a new wav file with ffmpeg. Even this doesn't make any difference. Strangest thing is, I also made a different clip from the same logic project, which doesn't make any trouble. Am I missing something, or is this a known bug. Can someone give me a hint.
By the way. If I remove the file from the Function List, QLC+ crashes.
Thanks in advance.
wrong bitrate at audio playback detected
Can you make a short wav that has this problem and attach it here?
Hello Jano,
thank you for your fast reply. I attached an example.
- Thunder.wav.zip
- (1.22 MiB) Downloaded 94 times
- Real Name: Ken Coughlin
I was able to recreate the problem using the file that was supplied, but I also imported that file into Audacity, and just exported it, and the exported files, with the same details, worked properly. I ran MediaInfo against both files, and there isn't that much difference between them. I've attached a screen shot of the MediaInfo screens.
I also brought the failing file into Cubase, and exported it. The Cubase created file has the same problem.
Fixed.
Please test the latest Windows test version and let me know if everything is working properly now.
