American DJ Vizi BSW 300
gmint
Real Name: George Qualley IV
New lights on the way! Can't wait to get them so I made a fixture definition in the meantime. I was able to find relatively close approximations of all of the gobos in the existing images except for one so I left that one out. Also, even though this definition should be accurate to the manual, I'll probably go back through and touch things up a little more once I have the actual fixture in hand.
American-DJ-Vizi-BSW-300.qxf
(12.35 KiB) Downloaded 39 times
American-DJ-Vizi-BSW-300.qxf.zip
(2.21 KiB) Downloaded 34 times
Added, thanks. Massive fixture !
gmint
Massimo,
I updated this fixture with some additional information. The split colors were grouped together under one "Color Indexing" header. Once I got the fixture and had the time, I went through and added the actual split colors which are not actually detailed in the manual. If you could use this one instead, it would be awesome!
(2.58 KiB) Downloaded 35 times
Updated, thanks !
