Is there already a fixture preset for these - got cheap off ebay to play around with and learn some DMX stuff
http://www.ebay.com.au/itm/322099989784 ... EBIDX%3AIT
thanks in advance
12W RGBW EBay
- MontyZuma
- Real Name: Klaus Muth
Without any documentation that's impossible to say. Since it has white LEDs, the Generic RGB won't work. But it's really not difficult to create such a simple fixture in the Fixture editor.
Since qlc+ is missing a definition for a generic RGBW fixture, I added a generic RGBW Fixture with this post. Try it. If it doesn't work for your fixture, get a PDF of the User Manual and post it (or better a link to it) here.
klaus
klaus
- Generic-Generic-RGBW.qxf
- (4.94 KiB) Downloaded 138 times
- Real Name: Dave Fragar
for what was bought as cheap off ebay they are ok value for the money for what i have seen of them so far - they are not $100 lights only $10 lights and this needs to be remembered
- page 2.pdf
- (825.7 KiB) Downloaded 124 times
- front.pdf
- (363.56 KiB) Downloaded 113 times
- Real Name: Mark Lohrey
Give this one ago.
You might like to edit the descriptions in the colour change channels. I just put them in as per the manual but they are rather long.
Cheers
Mark
Cheers
Mark
- Lanling-LPR1211.qxf
- (3.74 KiB) Downloaded 116 times
- Real Name: Steffen Rose
My interface is also on the way.. hopefully.
Meanwhile I've created my own fixture as I could't find any.
The name of my LED Spot is:
Lixada DMX-512 RGBW LED Stage PAR Light
http://www.lixada.com/stage-lighting-ef ... 581au.html
but looks like yours. Maybe this works for you as well.
I would appreciate if you give me feedback anyway
- lixada_15W_RGBW.qxf
- (3.55 KiB) Downloaded 136 times
Great news my USB interface arrived and the show that I had had pre setup using the supplied light profile worked spot on - running the lights in 5ch mode setup - so happy that just ordered another 8 lights from the suppler to get rid of all my non LED fixtures.
uv version found here
viewtopic.php?f=3&t=11258
