[ UPDATE - added all channel modes ( 22-15-7-3ch) and the similar Gesture wash model ]
Gesture Wash 102
2-sided Moving Head Wash - Wide 38.5° beam angle
http://www.marqlighting.com/products/vi ... e-wash-102
MANUAL:
http://0ab2dada4ff5ab031e87-2647250b48e ... 20v1.1.pdf
Gesture Beam 102
2-sided Moving Head Beam - 3.4° beam angle
http://www.marqlighting.com/products/vi ... e-beam-102
MANUAL:
Independent RGBW Color mixing for each side
Continuous Pan & Tilt for endless rotation on both axes
Marq Gesture Wash & Gesture beam 102 - ALL modes
- DESIGNFactory
- Real Name: John Yiannikakis
- Marq-Gesture-wash-102.qxf
- (13.15 KiB) Downloaded 38 times
- Marq-Gesture-beam-102.qxf
- (13.15 KiB) Downloaded 35 times
Fixed and added, thanks.
When there is only one head, you don't need to define it. QLC+ will do it for you.
Since the 2 fixtures were identical except for physical information (which was wrong anyway), I merged them and made a single fixture for Beam and Wash
- DESIGNFactory
cool thanks Massimo, just played around with the heads cause with 2 sided light heads i didn't know what to do so i was experimenting
after installing the lights, i understood it was a wrong approach from me anyway ....2 heads stop the light from moving, sorry i forgot to fix it afterwards...
btw, if you need any help in implementing any 3D stuff or objects in a future release, let me know, i will gladly help
thanks for all the good work, keep it on !
