Is it possible to set a slider level using a button?
I'd like to create around four buttons under a slider, each button with increasing intensity. When I click the button I want the slider to move to that level. I still want the ability to then change the level in the slider itself.
Even better would be if a single button could change the levels in several faders.
And finally, would be great to set the timing.
Control a slider using a button
- Real Name: Lukas
This is possible with the help of the loopback plugin.
Have a look at the workspace attached. The button sets the fader to a specific value, but the slider still is able to override it. You can scale this to as many sliders as you want. The only drawback is, that as soon as you switch of the button the slider goes back to 0.
(Tested on Xubuntu 14.04 64Bit (Qt5) with latest git sources)
- slider button.qxw
- (3.22 KiB) Downloaded 176 times
You can accomplish this using the feedback-feature
I've attached a project for you to discover how it works.
If in need of more info - just ask.
Good luck
Good luck
- knobs-set-slider.qxw
- (5.3 KiB) Downloaded 186 times
- Real Name: Collin
Can somebody explain how the button works? What are the key elements to add to it and what do they do?
I downloaded it and tried to figure it out but am new to this so could not get one working like it and couldn't find a way to cut and paste to my project to modify.
The main feature that is used here is loopback plugin. It allows to use output of anything in QLC+ as external input for something else.
In this case, each of the four buttons control channel 1 in Universe 2, that is used as external input for the slider.
To recreate the system, you need:
Besides these two universes, you'll need you normal universes for your DMX input (where your real fixtures are patched) and for external input from real controllers if you have any.
- separate control universe (one that is not used for DMX output; Universe 2 in this case)
- fixtures in this universe for every control channel (in this case only1, patched as dimmer -- that is easiest/most convenient)
- buttons in VC to control this channel via related scenes (each button starts respective scene and the scene sets level of the channel). Scenes here are called dummy 10, dummy 50, etc.
- Slider's external control is set to Universe 2, channel 1 (manually). You may create an input profile for easier selection.
- Real Name: certvalue
can somebody explain to me how this works I have no idea about this...thanks in advance
