I'm having issues with RGBMatrix on OSX.
I created a group of devices with 12x1 and any effect that I choose in the Matrix the system does not execute ...
I did the same in Windows and runs without problems .... someone already had this problem, how did you solve it?
RGB MATRIX does not execute
- Real Name: Alex Marques
Can you post the problematic workspace (qxw) + any custom qxf files?
Did you check DMX monitor? Does it show proper values?
How do you know the matrix does not execute?
Does not display anything on the DMX monitor ...
On PC if I use the same, it works normally ....
I was able to make the DMX monitor respond ...
Tomorrow I will test with the LEDs on.
The problem was in Fixture, I changed from LSB mode to MSB ....
Apparently it solved, I'll check the other devices I created.
