Set fixed Value
Posted: Sun Apr 02, 2017 9:18 am
by MontyZuma
Hi.
I've got an Stairville CLB 2.4 LED which has an "Dimmer" value.
https://images4.static-thomann.de/pics/ ... online.pdf
I'm using a fixture definition which was posted here. Now the Dimmer value is constantly in my way in scene definition since I have always have to set it to 255 in scenes - now if I attach a slider to that scene the output gets quadratic, because dimmer and RGB values move with the slider.
Is there a way to just fix that dimmer value to 255?
klaus
Re: Set fixed Value
Posted: Sun Apr 02, 2017 10:43 am
Put all your dimmers in a separate scene, remove them from other scenes.
Either create button that you will push at the start of the show or set the scene to autostart (see Image in Function Manager)
Re: Set fixed Value
Posted: Sun Apr 02, 2017 2:19 pm
by MontyZuma
Nice.
In the meantime I found a way to change the dimmer in the fixture editor so it only assumes values between 255 and 255.
This does the job but lacks the flexibility of your solution.
Thanks,
Klaus
