lightmaXX Platinum Tour PIX PRO 16x 8Watt Quad LED RGBW
Twenty
Real Name: Licaa
Hello! =)
If possible, I would like to have the fixture file for the lightmaXX Platinum Tour PIX PRO 16x 8Watt Quad LED RGBW.
here's the product https://www.musicstore.de/en_NO/NOK/lig ... 009215-000
here's the manual, english and german http://www.avolites.de/test/personaliti ... 15-000.pdf
Thanks a lot in advance. =)
Freasy
Real Name: Jan F
since the manual isn't that specific, what channel 1 does in 11, 19 and 67ch mode, please test if it does the same as in 7ch mode. And if 64ch mode is what I think it is, RGBW for every single lens.
And if the color pickers in Red 1 and Green 1 are correct for the Flow8 and 9 program.
Fixture passed the validator without errors.
lightmaXX-Platinum-Tour-PIX-PRO-16x-8W-Quad-LED-RGBW.qxf
(29.61 KiB) Downloaded 159 times
Twenty
Real Name: Licaa
I will, thank you!
Please report back if you have some results on testing so we can see if it is worth adding the fixture to the library.
