Hey guys,
there is some development going on around the speeddial widget. Especially the tap button was made flashing instead of blinking (and indicating the speed always, not only when tapped). In addition to that, the tap button sends now feedback to its external control.
We need to test the new flashing behavior with as much different controllers as we can, especially with small speeds/values of the widget. Below 125ms the tap feedback is disabled, until this value the feedback to an external controller should work well - this should be tested.
So if you have an external controller - please give it a try! (:
Link to github: https://github.com/siegmund42/qlcplus/t ... -speeddial
You can use the attached workspace made by enbyted.
Happy testing,
Speeddial improvements
- Real Name: Lukas
- tap_test.qxw
- (5.52 KiB) Downloaded 90 times
