QTX
nermong
Real Name: Nerijus Mongirdas
nermong
Adjust, please. Thanks
JBSYS-TEMS-twin-effect.qxf
(1.93 KiB) Downloaded 91 times
JB-Systems-Plano-Spot-LED.qxf
(4.3 KiB) Downloaded 88 times
Equinox-Domin8r.qxf
(2.5 KiB) Downloaded 92 times
https://jb-systems.eu/plano-spot
https://www.proaudiocentre.com/docs/EQLED53-um0.pdf
nermong
Adjust please. Thanks
QTX-LIGHT-LUX-LD-30.qxf
(3.13 KiB) Downloaded 86 times
QTX-LIGHT-MHS-60.qxf
(93.91 KiB) Downloaded 113 times
boxy
Real Name: Robert Box
Here's the QTX part adjusted. No idea why the pan/tilt channels had a channel range for EACH number.
QTX-MHS-60.qxf
(4.34 KiB) Downloaded 93 times
nermong
boxy wrote:Here's the QTX part adjusted. No idea why the pan/tilt channels had a channel range for EACH number.
thanks
nermong
Please help,I need fixtures Qtx light Lux-ld30w,Jbsystems light Twin effect.
floEdelmann
Real Name: Flo Edelmann
For the JB Systems Twin Effect Laser, see my reply on your other thread.
As for the QTX LUX-LD30W, that is also available from the Open Fixture Library. You can view it here: open-fixture-library.org/qtx/lux-ld30w
Just click Download as QLC+ in the top right corner.
nermong
floEdelmann wrote: Tue Sep 19, 2017 1:11 pm For the JB Systems Twin Effect Laser, see my reply on your other thread.
As for the QTX LUX-LD30W, that is also available from the Open Fixture Library. You can view it here: open-fixture-library.herokuapp.com/qtx/lux-ld30w
Thank you very much :D
I would like to submit the fixture definition for adding, but unfortunately, the pan/tilt degree information is missing. Can anyone help?
