- Chauvet DJ GigBAR 2 (Flo Edelmann - Open Fixture Library) This fixture still has two errors in the validator which cannot be fixed imo: The "White Strobe Dimmer" channel is indeed an intensity channel, but obviously only working when strobing (see manual). So the intensity type is correct, it should not be of type shutter
- American DJ Boom Box Fx2 (Felix Edelmann - Open Fixture Library)
- Showtec Dominator (Felix Edelmann - Open Fixture Library)
Help gathering complete definitions anyone ?
- Real Name: Lukas
Here we are - open fixture library extending (;
- Chauvet-DJ-GigBAR-2.qxf
- (14.85 KiB) Downloaded 115 times
- American-DJ-Boom-Box-Fx2.qxf
- (6.54 KiB) Downloaded 108 times
- Showtec-Dominator.qxf
- (8.27 KiB) Downloaded 115 times
- Fxedel
- Real Name: Felix Edelmann
The two last of them are mine (Felix Edelmann)siegmund wrote: ↑Sat Nov 18, 2017 12:43 pm Here we are - open fixture library extending (;
- American DJ Boom Box Fx2 (Flo Edelmann - Open Fixture Library)
- Showtec Dominator (Flo Edelmann - Open Fixture Library)
Thanks for posting here
Have a look at the Open Fixture Library! It's a project to collect fixture definitions in a unified format and make them downloadable for different lighting programs, including QLC+.
- Real Name: Lukas
Hey Massimo,
today I'll have a bunch of new fixtures for you. But first, I have a question for you since it arose twice now for the second time:
What about fixtures, which support endless Pan/Tilt?
So far this was the case for the following fixtures:
viewtopic.php?p=49630
viewtopic.php?p=50213
As Flo stated in the last thread, a possible solution could be to adapt the fixture definition scheme. In addition to that, the fixture validator should be updated.
Until this is solved, I won't submit these fixtures for adding them to QLC+ but will keep track of them in this post.
Greetings!
Lukas
Greetings!
Lukas
- Real Name: Lukas
Okay, actually there were just 2 new ones - the others are Chinese or very incomplete.
- JB-Lighting Varyscan P7 (Felix Edelmann - Open Fixture Library)
- American DJ Auto Spot 150 (Felix Edelmann - Open Fixture Library)
- JB-Lighting-Varyscan-P7.qxf
- (17.84 KiB) Downloaded 95 times
- American-DJ-Auto-Spot-150.qxf
- (5.47 KiB) Downloaded 100 times
- Real Name: Lukas
Quite some time has passed since the last update - so here comes the next one (since I've heard you're about to release 4.11.2 I hurried up a bit)!
- LaluceNatz 36W 9 Slim Par Light RGBW (mlohrey) - this may be one of the type you call "chinese fixtures"
- Showtec Sunraise LED (Felix Edelmann - Open Fixture Library)
- American DJ Revo Sweep (Felix Edelmann - Open Fixture Library) the direction of the pixels in 28ch mode (left-to-right or right-to-left) is not yet confirmed
- Chauvet FXpar 9 (Jungle Jim)
- Venue TriStrip3Z (Florian Edelmann - Open Fixture Library)
- American DJ Revo Burst (Florian Edelmann - Open Fixture Library)
- Ayra TDC Triple Burst (Florian Edelmann - Open Fixture Library)
- Orion Effects Lighting ORCAN2 (Felix Edelmann - Open Fixture Library) The correctness of the strobe channel is not yet confirmed and there is no information on power consumption available...
- LaluceNatz-36W-9-LED-Full-Color-RGBW.qxf
- (3.23 KiB) Downloaded 93 times
- Showtec-Sunraise-LED.qxf
- (3.45 KiB) Downloaded 98 times
- American-DJ-Revo-Sweep.qxf
- (11.29 KiB) Downloaded 96 times
- Real Name: Lukas
Some more fixture definition files...
- Chauvet-FXpar-9.qxf
- (10.54 KiB) Downloaded 93 times
- Venue-TriStrip3Z.qxf
- (9.87 KiB) Downloaded 96 times
- American-DJ-Revo-Burst.qxf
- (11.93 KiB) Downloaded 94 times
- Real Name: Lukas
Last two ones
- Ayra-TDC-Triple-Burst.qxf
- (10.03 KiB) Downloaded 100 times
- Orion-Effects-Lighting-ORCAN2.qxf
- (2.24 KiB) Downloaded 89 times
Very sorry Lukas !
I totally missed the latest updates to this thread
I have committed the new definitions with the new format.
- Real Name: Lukas
Hey Massimo,
I was very busy the last weeks but will have some spare time till September. So I thought about gathering latest complete definitions.
Since I did not follow the complete fixture definition rework process: Is there already a fixture validator for the new format? How can I convert fixtures to the new format and edit fixture definitions of new format? Do I have to use the QLC+5 fixture definition editor?
Or should I simply add the fixtures in the current format?
Lukas
Lukas
An online version no, offline yes. There is a python script in resources/fixtures/scripts called fixtures-tool.py. Launch it with --validate on a path.siegmund wrote: Is there already a fixture validator for the new format?
With the fixture definition editor. If you can either build from sources or use the latest test version.siegmund wrote: How can I convert fixtures to the new format and edit fixture definitions of new format?
There is no such editor.siegmund wrote: Do I have to use the QLC+5 fixture definition editor?
That is an option. I'll review the files anyway.siegmund wrote: Or should I simply add the fixtures in the current format?
[EDIT] a good example between old and new syntax is Stairville BS-280 R10 BeamSpot that I just committed.
Old was here: http://www.qlcplus.org/forum/viewtopic.php?f=3&t=12234
@Massimo,
Does it make sense to already upload 'my' adopted (v 4.11.120) fixture definitions?
Question comes from my idea that the aliases don't work yet??
(And IMHO the copy & paste possibility in the new physical tab doesn't make sense here now? (Or to copy from global to per-mode-physical tab?))
Anyway ... updated fixture definitions see annex
- fixtures.rar
- (14.14 KiB) Downloaded 101 times
What is 4.11.120 ??
Until 4.12.0 is released, you need to use the "old" fixture definition format.
Otherwise, start using 4.12.0 test builds and provide feedbacks.
For the record, where do the files in the RAR archive come from ?
They don't seem to be definitions requested in this forum area, nor they meet the meaning of this thread.
So why didn't you submit them in the fixture definition area like everybody else ?
