Two Updated Fixture definitons I'm using.
Better naming of Channels, Heads, corrected Channel Groups.
Help gathering complete definitions anyone ?
- MontyZuma
- Real Name: Klaus Muth
- Stairville-LEDbar-240-8.qxf
- Updated, Channels Sorted & better named
- (8.56 KiB) Downloaded 124 times
- Stairville-CLB2.4-CompactLED.qxf
- Updated, Heads
- (10.56 KiB) Downloaded 115 times
- MontyZuma
Difficult:mcallegari wrote: ↑Sun Apr 09, 2017 8:40 amThey don't even pass the fixture validator.
I guess you haven't even read the OP.
is a contradiction in itself - the only problem with the fixture validator is that modes shouldn't contain the word mode in the name, this is what they are called in the product user manual. So one of those conditions is violated in any case. Shall I invent a new name for each mode?Massimo Callegari wrote: ↑Mon Mar 09, 2015 7:33 pm
- A fixture should pass the online fixture validator to be accepted
- A fixture should reflect the exact indications given in the product user manual
The second doesn't validate because the manual says for the strobe effect "increasing speed" and the validator thinks it should belong to the speed group. But strobe is a shutter effect, isn't it?
So is it "should pass the validator" or is it "MUST pass the validator"?
k
And here we go again.MontyZuma wrote:is a contradiction in itself - the only problem with the fixture validator is that modes shouldn't contain the word mode in the name, this is what they are called in the product user manual. So one of those conditions is violated in any case. Shall I invent a new name for each mode?
Do you want to be right ? You're right then. Happy ?
The word "should" says it all. The rest is common sense.
In the QLC+ add fixture dialog there is "Mode" and a combo box. Therefore "Mode: 13 channel mode" doesn't sound that right.
Plus, multiply the word "mode" by all the modes of 870 fixtures and you'll have the amount of all the useless bytes that would go into the QLC+ package.
Also, if a fixture manual is available only in german, would you stick to it and write a fixture definition in german for everybody in the world ? Please be reasonable.
The whole point here is that I started this topic to ask for some help because I was way behind with the review of the fixtures submitted in this forum area.
Instead, you took a random post and posted an update of an existing fixture and a new one no one has ever seen. Both should have gone in a new thread in the Fixture definitions area.
But who am I to say this forum is a total mess cause people refuse to simply choose the right place ?
- MontyZuma
Yeah. You are right of course.mcallegari wrote: ↑Sun Apr 09, 2017 12:13 pmAnd here we go again.MontyZuma wrote:is a contradiction in itself - the only problem with the fixture validator is that modes shouldn't contain the word mode in the name, this is what they are called in the product user manual. So one of those conditions is violated in any case. Shall I invent a new name for each mode?
I have to admit I was a little bit pissed - please forgive me, that's not your fault. I really should know better.
Of course that was the wrong thread. I'll come up with some idea how to include the mode number from the manual without using "mode" in the name and will resubmit in the right place.
klaus
- Real Name: Lukas
Two new definitions:
- Beamz BAC406
- Geni Mojo color 150 (but I'm not completely sure if this is not what you call a "chinese fixture")
- Beamz-BAC406.qxf
- (4.74 KiB) Downloaded 100 times
- Geni-Mojo-Color-Moc.qxf
- (1.95 KiB) Downloaded 103 times
- Real Name: Lukas
New definition:
- Stairville-MH-250-S.qxf
- (6.05 KiB) Downloaded 88 times
- Real Name: Lukas
Next round!
- Chauvet GigBAR 2 (Freasy/Jan F) [In this one there are still errors from the validator but they are not fixable accordingt to Freasy's post]
- Pro Lights Onyx (Freasy/Jan F)
- Big Dipper LPC006 (todopic/Norberto Pellegrini)
- Coemar ProSpot 250 LX (Flo Edelmann - Open Fixture Library)
- Showtec Kanjo Spot 60 (Flo Edelmann - Open Fixture Library)
- fixtures.zip
- (9.49 KiB) Downloaded 88 times
All added except for Big Dipper which is in Spanish.
Thanks a lot Lukas !
For when we'll ever have 3D laser simulationOne question: What is the sense behind requiring the pan/tilt degree information on a laser fixture?
- Real Name: Lukas
Here we are - open fixture library extending (;
- Chauvet DJ GigBAR 2 (Flo Edelmann - Open Fixture Library) This fixture still has two errors in the validator which cannot be fixed imo: The "White Strobe Dimmer" channel is indeed an intensity channel, but obviously only working when strobing (see manual). So the intensity type is correct, it should not be of type shutter
- American DJ Boom Box Fx2 (Felix Edelmann - Open Fixture Library)
- Showtec Dominator (Felix Edelmann - Open Fixture Library)
- Chauvet-DJ-GigBAR-2.qxf
- (14.85 KiB) Downloaded 101 times
- American-DJ-Boom-Box-Fx2.qxf
- (6.54 KiB) Downloaded 99 times
- Showtec-Dominator.qxf
- (8.27 KiB) Downloaded 100 times
- Fxedel
- Real Name: Felix Edelmann
The two last of them are mine (Felix Edelmann)siegmund wrote: ↑Sat Nov 18, 2017 12:43 pm Here we are - open fixture library extending (;
- American DJ Boom Box Fx2 (Flo Edelmann - Open Fixture Library)
- Showtec Dominator (Flo Edelmann - Open Fixture Library)
Thanks for posting here
Have a look at the Open Fixture Library! It's a project to collect fixture definitions in a unified format and make them downloadable for different lighting programs, including QLC+.
- Real Name: Lukas
Hey Massimo,
today I'll have a bunch of new fixtures for you. But first, I have a question for you since it arose twice now for the second time:
What about fixtures, which support endless Pan/Tilt?
So far this was the case for the following fixtures:
viewtopic.php?p=49630
viewtopic.php?p=50213
As Flo stated in the last thread, a possible solution could be to adapt the fixture definition scheme. In addition to that, the fixture validator should be updated.
Until this is solved, I won't submit these fixtures for adding them to QLC+ but will keep track of them in this post.
Greetings!
Lukas
Greetings!
Lukas
- Real Name: Lukas
Okay, actually there were just 2 new ones - the others are Chinese or very incomplete.
- JB-Lighting Varyscan P7 (Felix Edelmann - Open Fixture Library)
- American DJ Auto Spot 150 (Felix Edelmann - Open Fixture Library)
- JB-Lighting-Varyscan-P7.qxf
- (17.84 KiB) Downloaded 89 times
- American-DJ-Auto-Spot-150.qxf
- (5.47 KiB) Downloaded 91 times
- Real Name: Lukas
Quite some time has passed since the last update - so here comes the next one (since I've heard you're about to release 4.11.2 I hurried up a bit)!
- LaluceNatz 36W 9 Slim Par Light RGBW (mlohrey) - this may be one of the type you call "chinese fixtures"
- Showtec Sunraise LED (Felix Edelmann - Open Fixture Library)
- American DJ Revo Sweep (Felix Edelmann - Open Fixture Library) the direction of the pixels in 28ch mode (left-to-right or right-to-left) is not yet confirmed
- Chauvet FXpar 9 (Jungle Jim)
- Venue TriStrip3Z (Florian Edelmann - Open Fixture Library)
- American DJ Revo Burst (Florian Edelmann - Open Fixture Library)
- Ayra TDC Triple Burst (Florian Edelmann - Open Fixture Library)
- Orion Effects Lighting ORCAN2 (Felix Edelmann - Open Fixture Library) The correctness of the strobe channel is not yet confirmed and there is no information on power consumption available...
- LaluceNatz-36W-9-LED-Full-Color-RGBW.qxf
- (3.23 KiB) Downloaded 85 times
- Showtec-Sunraise-LED.qxf
- (3.45 KiB) Downloaded 89 times
- American-DJ-Revo-Sweep.qxf
- (11.29 KiB) Downloaded 87 times
- Real Name: Lukas
Some more fixture definition files...
- Chauvet-FXpar-9.qxf
- (10.54 KiB) Downloaded 86 times
- Venue-TriStrip3Z.qxf
- (9.87 KiB) Downloaded 88 times
- American-DJ-Revo-Burst.qxf
- (11.93 KiB) Downloaded 86 times
- Real Name: Lukas
Last two ones
- Ayra-TDC-Triple-Burst.qxf
- (10.03 KiB) Downloaded 92 times
- Orion-Effects-Lighting-ORCAN2.qxf
- (2.24 KiB) Downloaded 80 times
Very sorry Lukas !
I totally missed the latest updates to this thread
I have committed the new definitions with the new format.
- Real Name: Lukas
Hey Massimo,
I was very busy the last weeks but will have some spare time till September. So I thought about gathering latest complete definitions.
Since I did not follow the complete fixture definition rework process: Is there already a fixture validator for the new format? How can I convert fixtures to the new format and edit fixture definitions of new format? Do I have to use the QLC+5 fixture definition editor?
Or should I simply add the fixtures in the current format?
Lukas
Lukas
