Hi all, is there a good soul willing to gather all the fixture definitions of the fulfilled requests in this area ?
I thought I could, but I really am not able to follow this particular forum. I normally add fixtures from "Fixture definitions".
I have unread posts from April 15th 2016: Smoke Factory Tour Hazer II Fixture request
The task is to check definitions from the date above with the fixture validator and inform me which ones are good. Basically a post with the "good links" would be enough.
Please do not consider chinese stuff or incomplete ones. If they're missing just some tiny bits then see if they can easily be fixed and eventually post the final qxf file.
I feel there are some good ones in here but I really don't have time to process all the posts.
The QLC+ project produces too much input for me alone and I need to prioritize things.
Well, thanks in advance to anyone willing to help !
Help gathering complete definitions anyone ?
- Real Name: Lukas
Hey Massimo,
I have some spare time over the next few days so I could give it a try.
Do you have a date in mind, by which everything should be finished (or release of next version)?
If you want, I could directly set up a pull request for the definitions.
Hi Lukas, thanks for offering, much appreciated.
No due date at all. I have no idea ATM when the next QLC+ version will be released, so please take all the time you need.
As for pull requests, for now I prefer to have the files (or links) here. On GitHub I'd risk to overlook at something that I might see more clearly with the definition editor.
Thanks again
Thanks again
- Real Name: Lukas
I add a post to sum up my results. I'll edit this until I finished so that I don't forget where I stopped.
- Smoke Hazer II: viewtopic.php?f=6&t=9814
- ADJ Tri phase: viewtopic.php?f=6&t=9888
- ADJ TriSpot: viewtopic.php?f=6&t=9886
- JB Systems Panther: viewtopic.php?f=6&t=9889
- Contest STB 520: viewtopic.php?f=6&t=9987
- A bunch of ADJ fixtures: viewtopic.php?f=6&t=9986
- Excelighting Color Spot NS 530 and Geni OBY 5: viewtopic.php?f=6&t=9994
- ETC Colorsource Par: viewtopic.php?f=6&t=10008&p=46870#p46870
- Cameo CLM Par COB 1: viewtopic.php?f=6&t=9957&p=46871#p46871
- Stairville DCL Flat: viewtopic.php?f=6&t=9958
- Big dipper LP001 (this points to a thread in fixture definitions section but the fixture is not yet integrated): viewtopic.php?f=3&t=10124
- Pro Lights Moonstone: viewtopic.php?f=6&t=10087
- Robe Spot 160 XT: viewtopic.php?f=6&t=10118&p=46874#p46874
- Briteq Tornado 7: viewtopic.php?f=6&t=10160
- ADJ 5P: viewtopic.php?f=6&t=10314
- Lixada Mini Moving Head (this is most probably what you call a "Chinese fixture" so I did not dig deeper into it. Let me know if you decide differently): viewtopic.php?f=6&t=10135
- Elumen8 Cob Tri 4 Pixel Batten: viewtopic.php?f=6&t=10451
- Chauvet intimidator Hybrid 140SR: viewtopic.php?f=6&t=10475
- lightmaXX 5 Five STAR: viewtopic.php?f=6&t=9171&p=46875#p46875
- Eyourlife 54X3W LED DJ PAR: viewtopic.php?f=6&t=10481&p=46876#p46876
- Robe DLX spot: viewtopic.php?f=6&t=10553&p=46885#p46885
- BL 252 Light Bar: viewtopic.php?f=6&t=10754&p=46886#p46886
- Showtec Compact Power Lightset COB: viewtopic.php?f=6&t=10700&p=46887#p46887
- new fistures.zip
- (41.3 KiB) Downloaded 112 times
- Real Name: Lukas
I think I'm done.
Tried to avoid fixtures that are already included or Chinese ones. If I didn't miss anything, they all pass the validator.
Please note, that I did not exactly reviewed the correctness of every single definition because of a lack of experience creating fixture definitions. However I did a short check for every fixture definition if it roughly matches the manual.
In addition to that, I'm not quite sure if I covered all the threads you haven't processed yet, since there where some, that you've already added.
From time to time I can look back in this section and report new fixtures in here.
If you need further help/information, please let me know.
All pushed !
THANK YOU very much Lukas ! Your help has been very precious and saved me a lot of time.
You're doing a lot for this project and I can only thank you again
- Real Name: Lukas
Two new definitions:
- Stairville Tri Flat PAR Profile 5x3W RGB thanks to Freasy: viewtopic.php?f=6&t=10890
- QTX MHS-60 thanks to Nerijus Mongirdas (and Robert Box): viewtopic.php?f=6&t=10897
- Stairville-Tri-Flat-PAR-Profile-5x3W-RGB.qxf
- (4.71 KiB) Downloaded 100 times
- QTX-MHS-60.qxf
- (4.34 KiB) Downloaded 149 times
- Real Name: Lukas
Three new fixture definitions:
- Marq-Colormax-Par64.qxf
- (4.96 KiB) Downloaded 100 times
- Eurolite-LED-TMH-FE-600.qxf
- (4.74 KiB) Downloaded 120 times
- Showtec-Power-Spot-Q5.qxf
- (6.43 KiB) Downloaded 98 times
- MontyZuma
- Real Name: Klaus Muth
Two Updated Fixture definitons I'm using.
Better naming of Channels, Heads, corrected Channel Groups.
- Stairville-LEDbar-240-8.qxf
- Updated, Channels Sorted & better named
- (8.56 KiB) Downloaded 125 times
- Stairville-CLB2.4-CompactLED.qxf
- Updated, Heads
- (10.56 KiB) Downloaded 115 times
- MontyZuma
Difficult:mcallegari wrote: ↑Sun Apr 09, 2017 8:40 amThey don't even pass the fixture validator.
I guess you haven't even read the OP.
is a contradiction in itself - the only problem with the fixture validator is that modes shouldn't contain the word mode in the name, this is what they are called in the product user manual. So one of those conditions is violated in any case. Shall I invent a new name for each mode?Massimo Callegari wrote: ↑Mon Mar 09, 2015 7:33 pm
- A fixture should pass the online fixture validator to be accepted
- A fixture should reflect the exact indications given in the product user manual
The second doesn't validate because the manual says for the strobe effect "increasing speed" and the validator thinks it should belong to the speed group. But strobe is a shutter effect, isn't it?
So is it "should pass the validator" or is it "MUST pass the validator"?
k
And here we go again.MontyZuma wrote:is a contradiction in itself - the only problem with the fixture validator is that modes shouldn't contain the word mode in the name, this is what they are called in the product user manual. So one of those conditions is violated in any case. Shall I invent a new name for each mode?
Do you want to be right ? You're right then. Happy ?
The word "should" says it all. The rest is common sense.
In the QLC+ add fixture dialog there is "Mode" and a combo box. Therefore "Mode: 13 channel mode" doesn't sound that right.
Plus, multiply the word "mode" by all the modes of 870 fixtures and you'll have the amount of all the useless bytes that would go into the QLC+ package.
Also, if a fixture manual is available only in german, would you stick to it and write a fixture definition in german for everybody in the world ? Please be reasonable.
The whole point here is that I started this topic to ask for some help because I was way behind with the review of the fixtures submitted in this forum area.
Instead, you took a random post and posted an update of an existing fixture and a new one no one has ever seen. Both should have gone in a new thread in the Fixture definitions area.
But who am I to say this forum is a total mess cause people refuse to simply choose the right place ?
- MontyZuma
Yeah. You are right of course.mcallegari wrote: ↑Sun Apr 09, 2017 12:13 pmAnd here we go again.MontyZuma wrote:is a contradiction in itself - the only problem with the fixture validator is that modes shouldn't contain the word mode in the name, this is what they are called in the product user manual. So one of those conditions is violated in any case. Shall I invent a new name for each mode?
I have to admit I was a little bit pissed - please forgive me, that's not your fault. I really should know better.
Of course that was the wrong thread. I'll come up with some idea how to include the mode number from the manual without using "mode" in the name and will resubmit in the right place.
klaus
- Real Name: Lukas
- Beamz BAC406
- Geni Mojo color 150 (but I'm not completely sure if this is not what you call a "chinese fixture")
- Beamz-BAC406.qxf
- (4.74 KiB) Downloaded 100 times
- Geni-Mojo-Color-Moc.qxf
- (1.95 KiB) Downloaded 104 times
- Real Name: Lukas
New definition:
- Stairville-MH-250-S.qxf
- (6.05 KiB) Downloaded 89 times
- Real Name: Lukas
Next round!
- Chauvet GigBAR 2 (Freasy/Jan F) [In this one there are still errors from the validator but they are not fixable accordingt to Freasy's post]
- Pro Lights Onyx (Freasy/Jan F)
- Big Dipper LPC006 (todopic/Norberto Pellegrini)
- Coemar ProSpot 250 LX (Flo Edelmann - Open Fixture Library)
- Showtec Kanjo Spot 60 (Flo Edelmann - Open Fixture Library)
- fixtures.zip
- (9.49 KiB) Downloaded 88 times
All added except for Big Dipper which is in Spanish.
Thanks a lot Lukas !
For when we'll ever have 3D laser simulationOne question: What is the sense behind requiring the pan/tilt degree information on a laser fixture?
