Re: udev rules
Posted: Sun Feb 12, 2017 8:33 pm
by Fendo
I have a similar problem.
Using a DIY FX5, windows 10 64bit and QLC+ 4.10.5b.
I start QLC+ and plug in the FX5. All is working fine until i plug in another USB device.
Then i get the Error Message posted above.
Edit: Tested it with the Nodle U1. Same problem.
Re: udev rules
Posted: Mon Feb 13, 2017 1:33 pm
Sounds like this is not supported unless you guys provide some details about the device. In particular the USB VID/PID.
If they're different from the original FX5, then QLC+ might treat them like a generic HID device, which are normally input only devices
Re: udev rules
Posted: Mon Feb 13, 2017 7:42 pm
by shortylight
Hi Massimo,
I took a closer look to the FX5. Although the device is operating properly as output and input device, there are differences regarding the used OS. For that reason QLC+ (4.10.5b) is not able to print out the Manufacturer "Digital Enlightenment" with Windows 8.1 64 BIT and Windows 10 64 BIT and also the Product string "USB DMX" is not shown.
With usbtreeview
http://www.uwe-sieber.de/usbtreeview_e.html you see some differences in the description of the USB device:
Win 7
=========================== USB Port4 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 1-4
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : USB-Eingabegerät
Device Path : \\?\usb#vid_16c0&pid_088b#0000000010001117#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_16C0&PID_088B\0000000010001117
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0025 (GUID_DEVCLASS_HIDCLASS)
Driver : C:\Windows\system32\DRIVERS\hidusb.sys (Version: 6.1.7601.17514 Date: 2010-11-20)
Driver Inf : C:\Windows\inf\input.inf
Legacy BusType : PNPBus
Class : HIDClass
Class GUID : {745a17a0-74d3-11d0-b6fe-00a0c90f57da} (GUID_DEVCLASS_HIDCLASS)
Interface GUID : {a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Service : HidUsb
Enumerator : USB
Location Info : Port_#0004.Hub_#0001
Location IDs : PCIROOT(0)#PCI(1C06)#PCI(0000)#USBROOT(0)#USB(4)
Container ID : {a2f5fd47-4b17-5448-858f-930a9191d021}
Manufacturer Info : (Standardsystemgeräte)
Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Problem Code : 0
Power State : D0 (supported: D0, D2, D3, wake from D0, wake from D2)
Child Device 1 : HID-konformes Gerät
Device ID : HID\VID_16C0&PID_088B\7&85DBB8F&0&0000
Class : HIDClass
---------------- Connection Information ---------------
Connection Index : 0x04 (4)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x01
Device Address : 0x01 (1)
Is Hub : 0x00 (no)
Number Of Open Pipes : 0x02 (2)
Device Bus Speed : 0x01 (Full-Speed)
Pipe0ScheduleOffset : 0x00 (0)
Pipe1ScheduleOffset : 0x00 (0)
------------------ Device Descriptor ------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x110 (USB Version 1.10)
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x08 (8 bytes)
idVendor : 0x16C0
idProduct : 0x088B
bcdDevice : 0x0110
iManufacturer : 0x01 (String Descriptor 1)
Language 0x0409 : "Digital Enlightenment"
iProduct : 0x02 (String Descriptor 2)
Language 0x0409 : "USB DMX"
iSerialNumber : 0x03 (String Descriptor 3)
Language 0x0409 : "0000000010001117"
bNumConfigurations : 0x01
------------------ String Descriptors -----------------
------ String Descriptor 0 ------
bLength : 0x04 (4 bytes)
bDescriptorType : 0x03 (String Descriptor)
Language ID[0] : 0x0409 (English - United States)
------ String Descriptor 1 ------
bLength : 0x2C (44 bytes)
------ String Descriptor 2 ------
bLength : 0x10 (16 bytes)
------ String Descriptor 3 ------
bLength : 0x22 (34 bytes)
---------------- Configuration Descriptor -----------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x0029 (41 bytes)
bNumInterfaces : 0x01
bConfigurationValue : 0x01
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0x80
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x00 (no)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0x64 (200 mA)
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00
bAlternateSetting : 0x00
bNumEndpoints : 0x02 (2 Endpoints)
bInterfaceClass : 0x03 (HID - Human Interface Device)
bInterfaceSubClass : 0x00 (None)
bInterfaceProtocol : 0x00 (None)
iInterface : 0x00 (No String Descriptor)
------------------- HID Descriptor --------------------
bDescriptorType : 0x21 (HID Descriptor)
bcdHID : 0x0110 (HID Version 1.10)
bCountryCode : 0x00 (00 = not localized)
bNumDescriptors : 0x01
Descriptor 1:
bDescriptorType : 0x22 (Class=Report)
wDescriptorLength : 0x0024 (36 bytes)
06 A0 FF Usage Page (unk)
09 A5 Usage (0xA5)
A1 01 Collection (Application)
09 A6 Usage (0xA6)
09 A7 Usage (0xA7)
15 00 Logical Minimum (0)
25 FF Logical Maximum (-1)
75 08 Report Size (8)
95 21 Report Count (33)
82 22 01 Input (Var, PrefState, BuffBytes)
09 A9 Usage (0xA9)
92 22 01 Output (Var, PrefState, BuffBytes)
C0 End Collection
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
bmAttributes : 0x03 (TransferType=Interrupt)
wMaxPacketSize : 0x0021 (33 bytes)
bInterval : 0x01 (1 ms)
bEndpointAddress : 0x02 (Direction=OUT EndpointID=2)
and Win 10:
=========================== USB Port1 ===========================
Port Chain : 3-1-1
Properties : 0x01
IsUserConnectable : yes
PortIsDebugCapable : no
PortHasMultiCompanions : no
Device Path : \\.\usb#vid_16c0&pid_088b#0000000010001117#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0015 (GUID_DEVCLASS_HIDCLASS)
Driver : C:\Windows\System32\drivers\hidusb.sys (Version: 10.0.10586.0 Date: 2015-10-30)
Class : HIDClass
Service : HidUsb
Enumerator : USB
Location Info : Port_#0001.Hub_#0005
Problem Code : 0
Power State : D0 (supported: D0, D3, wake from D0)
Connection Index : 0x01 (1)
Device Address : 0x06 (6)
Is Hub : 0x00 (no)
--------------- Connection Information V2 -------------
SupportedUsbProtocols : 0x03
Usb110 : 1 (yes)
Usb200 : 1 (yes)
Usb300 : 0 (no)
ReservedMBZ : 0x00
Flags : 0x00
DevIsOpAtSsOrHigher : 0 (Is not operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 0 (Is not SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 0 (Is not SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
idVendor : 0x16C0
idProduct : 0x088B
bcdDevice : 0x0110
bmAttributes : 0x80
Descriptor 1:
09 A5 Usage (0xA5)
09 A6 Usage (0xA6)
09 A7 Usage (0xA7)
09 A9 Usage (0xA9)
C0 End Collection
Maybe this helps. Please write if you need further information.
Regards Martin
Re: udev rules
Posted: Mon Feb 13, 2017 10:01 pm
Disclaimer: I don't have any HID device available and I don't know anything about FX5.
1.
https://fx5.de/ contains this message:
Windows 8.1 und Windows 10: Wenn Sie Windows 8.1 oder Windows 10 benutzen, schließen Sie das Interface bitte zunächst an, starten den FX5-Installer und klicken auf "Installieren". Danach trennen Sie das Interface noch einmal vom Computer und schließen es erneut an. Danach ist das Gerät einsatzbereit.
I think you all guys are from Germany, but for others it says that for win8.1 and 10 do the following: connect the device, run installer, and replug the device.
2. only commits relevant to HID are these:
https://github.com/mcallegari/qlcplus/c ... a0407861a2
https://github.com/mcallegari/qlcplus/c ... 29a0ec499f
So it may be related to hotplug (this is supported by Fendo's comment "All is working fine until i plug in another USB device.")
3. HID API has some changes in git repo, not released yet. It may be useful to integrate them.
Re: udev rules
Posted: Tue Feb 14, 2017 11:20 am
by Fendo
Hey,
the DIY FX5 have the same Firmware as the normal FX5. Same components and so on. So there is no different between them.
I also testet the Nodle U1 from DMXControl Project. (Which is based on the FX5) Its absolutly the same issue.
I tested the Installer from the FX5 site. The FX5 is not detected from the Installer and no Software is installed.
Re: udev rules
Posted: Tue Feb 14, 2017 11:39 am
by Fendo
Here is my output of the DIY FX5 and the Nodle U1 from usbtreeview.
Both Win10 64bit
DIY FX5
Port Chain : 2-4
Properties : 0x01
PortConnectorIsTypeC : no
ConnectionIndex : 4
CompanionIndex : 0
CompanionHubSymLnk : USB#ROOT_HUB30#4&ffe561e&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
CompanionPortNumber : 8
Device Path : \\?\usb#vid_04b4&pid_0f1f#0000000000112013#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_04B4&PID_0F1F\0000000000112013
Hardware IDs : USB\VID_04B4&PID_0F1F&REV_0110 USB\VID_04B4&PID_0F1F
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0005 (GUID_DEVCLASS_HIDCLASS)
Driver : C:\WINDOWS\System32\drivers\hidusb.sys (Version: 10.0.14393.82 Date: 2016-11-24)
Driver Inf : C:\WINDOWS\inf\input.inf
Class : HIDClass
Service : HidUsb
Enumerator : USB
Location Info : Port_#0004.Hub_#0003
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(4), ACPI(_SB_)#ACPI(PCI0)#ACPI(XHC_)#ACPI(RHUB)#ACPI(HSP4)
Container ID : {d296e707-beab-5de3-98d9-756c8ae6747a}
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
Power State : D3 (supported: D0, D3, wake from D0)
Child Device 1 : HID-konformes, vom Hersteller definiertes Gerät
Device ID : HID\VID_04B4&PID_0F1F\6&70AAD77&2&0000
Class : HIDClass
Is Hub : 0x00 (no)
Usb110 : 1 (yes)
Usb200 : 1 (yes)
Usb300 : 0 (no)
ReservedMBZ : 0x00
Flags : 0x00
ReservedMBZ : 0x00
idVendor : 0x04B4 (Cypress Semiconductor)
idProduct : 0x0F1F
bcdDevice : 0x0110
bmAttributes : 0x80
Descriptor 1:
Error reading descriptor : ERROR_GEN_FAILURE
Nodle U1
Port Chain : 2-4
Properties : 0x01
ConnectionIndex : 4
CompanionIndex : 0
Device Path : \\.\usb#vid_16d0&pid_0830#5555555555555555#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
Device ID : USB\VID_16D0&PID_0830\5555555555555555
Hardware IDs : USB\VID_16D0&PID_0830&REV_0103 USB\VID_16D0&PID_0830
Driver KeyName : {745a17a0-74d3-11d0-b6fe-00a0c90f57da}\0009 (GUID_DEVCLASS_HIDCLASS)
Class : HIDClass
Service : HidUsb
Enumerator : USB
Container ID : {2da37a04-39ed-50bb-b513-265233f139a4}
Problem Code : 0
Device ID : HID\VID_16D0&PID_0830\6&1624E9E5&1&0000
Class : HIDClass
Device Address : 0x02 (2)
Is Hub : 0x00 (no)
Usb110 : 1 (yes)
Usb200 : 1 (yes)
Usb300 : 0 (no)
ReservedMBZ : 0x00
Flags : 0x00
ReservedMBZ : 0x00
idVendor : 0x16D0
idProduct : 0x0830
bcdDevice : 0x0103
Language 0x0409 : "DMXControl Projects e.V."
Language 0x0409 : "Nodle U1"
Language 0x0409 : "5555555555555555"
bLength : 0x32 (50 bytes)
bmAttributes : 0x80
Descriptor 1:
At the moment i avoid the problem by using my secound OS Debian on my laptop.
There everything is working fine
Re: udev rules
Posted: Wed Feb 15, 2017 12:30 pm
by BartM
the Problem with the udev rules was only on my PC.
I try it on the notebook with the version 4.10.5 and i can yous my DE interface also as output.
