Cue List Steps Fader not responding to OSC correctly
Posted: Sat Feb 04, 2017 7:29 am
Before i finished this I found it functioned correctly if the OSC values are between 0 and 1 (descending as the cues increase is sorta weird but fine)
so this is minor now but probably still worth fixing: If you send integer values from 1 to 255 as the OSC message it moves the fader correctly until it gets to 127. Above that it jumps to the 255 position and stays there. Its easily reproducible with any size cue list and several recent versions.
I personally think it would make a lot more sense if integer values picked the cue number rather than the fader position. Maybe that could be a different control channel.
Also you may want to change the wording in the properties panel when its set to steps mode to indicate that only the "left fader" is used. maybe just disable the right fader settings when steps is selected.
