Eurolite ERX4 DMX
Posted: Thu Jan 12, 2017 6:43 pm
by jszabolcs2006
A simple 4 channel relay switcher, with 2 modes.
Users manual: http://www.produktinfo.conrad.com/daten ... _fr_es.pdf
Corrected the file, added heads so the 2D view shows the 4 channels now.
Re: Eurolite ERX4 DMX
Posted: Thu Feb 23, 2017 10:00 pm
by siegmund
Thanks for sharing! Since this is a simple dimmer pack, there is no need to create an extra fixture. Simply use the Generic dimmer with 4 channels.
Posted: Tue Mar 28, 2017 4:49 pm
by jszabolcs2006
I made this fixture, because it has 2 modes (1ch dmx controls all 4 output, or 4ch where each channel has its dmx channel), and it is a Switcher pack, not a dimmer. So the channel values make a channel on/off, instead of dimming.
Posted: Fri Apr 07, 2017 9:36 am
by siegmund
Okay, I see now. But I'm still not sure if we should add this type of fixtures.
@massimo, what is your opinion?
Posted: Tue Apr 25, 2017 5:13 pm
by jszabolcs2006
If you do not want to add this exact fixture, then maybe you could make a generic switcher, just like the generic dimmer. It would make sense, since they work all in the same way as I know. :)
