I use EFX functions for my LightmaXX Easy Wash QUAD LED (self-made fixture). They have been working well with 4.10.4 and 4.10.3 (not tested older releases), but now with 4.10.5b they do not move anymore. All movements and other functions aside the EFX functions are still working properly with the moving heads, that's why I think the fixture must be ok. I have tried to create new EFX functions already and that does not work either.
Any idea?
Thanks and best regards
Ben
EFX not working in 4.10.5b
Please post your custom fixture, your workspace and the steps to reproduce the issue you're seeing.
Saying "it doesn't work" doesn't help much
Here you go, thanks
- Amplifiers DH.qxw
- (295.94 KiB) Downloaded 67 times
- LightmaXX-Easy-Wash-QUAD-LED-V.2.0.qxf
- (4.73 KiB) Downloaded 69 times
As I suspected, your fixture is messed up.
Check it with the online fixture validator: http://www.qlcplus.org/fixture_validator.php
There are 8 errors.
Previous QLC+ versions allowed a bad usage of Pan/Tilt fine. 4.10.5b doesn't allow it anymore. The definition must be correct.
P.S. "Ran/Tilt Speed"...really ? "Movment" ?
There are 8 errors.
