Random Crashes :-(
hplighting wrote: Fri Jun 09, 2017 7:37 pm
mcallegari wrote: Fri Jun 09, 2017 6:21 pm Hey guys, I think this time I've got it.
Please test as soon as you can Windows version 4.11.0.103
Thanks Massimo :-)
I'll try and give it a go, doing a festival next weekend so hopefully this will have fixed it!
What was causing the crash in the end?
Henry P
As mentioned before, it was not a crash. If it was, I would have found a solution way earlier !
The QLC+ process was completely freezing and it was not possible to kill it completely (thus the only way to recover was to reboot Windows)
The cause is not so easy to explain. It was a mixture of UI updates and MIDI signals (I think feedbacks were involved too)
The latest change separates engine updates from UI updates and it seems to be the way to go.
dino.loss
Real Name: Dino Loss
Please test as soon as you can Windows version 4.11.0.105
If it doesn't freeze anymore, please help me also to test inverted sliders, range values, monitor level, controller feedbacks, etc.
Basically I need to make sure I haven't regressed on anything else.
This is the last issue blocking 4.11.0 to be released.
I'm sorry, nothing has changed, same identical problem!
The only way to avoid blocking is to disable feedback on the apc mini
AKAI APC mini
Behringer Eurolight LC2412
Enttec DMX USB PRO MK2
Windows 7 64
Hey guys, new test build available (116)
Please give it a go and report.
This is taking too long to get fixed and I really need to release 4.11.0
Thanks for the cooperation
luca
Real Name: lucas
hi ,
This is my experience with 4.10.5b and 4.11.0.xxx on windows 10 (windows 7 works properly) :
1 - open qlc+
2 - go to Inputs/Outputs
3 - set midi in on universe ( 1 2 3 or 4)
4 - connect, or disconnect, one usb device ( usb pendrive, mouse)
Now I lost midi comunication .
For restore comunication:
5 - With a double click on a midi line "MIDI" on "Mapping" pannel, open configure midi plugin
6 - Press "Refresh" to find midi device
Some times windows display "qlc has stoped to working" .
Luca
viewtopic.php?f=24&t=11240
dino.loss
Test done!
This time everything works smoothly, I tried 1 hour without any problems
QLC+ 4.11.0.116
Windows 7 64bit
Dino
AKAI APC mini
Windows 7 64
