In creating a new definition I've discovered a bit of a bug in the UI.
OS: Windows 7 Pro
QLC: 4.10.5a
After you have "activated" the editing pane by double-clicking on a capability line, you can single-click any other line to supposedly edit that line. The problem is that you're not really editing that new line, but the same line that you just double clicked. After you enter that new information, it will be displayed in the capability list, but not actually be saved when you click the OK button at the end of the process. See below for step-by-step to reproduce:
Open the edit channel window, then double click a capability line to edit it.
Single-click another line.
Enter in the new information for that line, it will be displayed in the entry field and the capability list.
Channel descriptions not being saved
- fooschnickens
- Real Name: Taylor
After clicking the OK button, you will not have any of the new information saved to the channel list. Only the line that you double clicked will have any modifications saved, and those modifications will be for the latest change that you made.
Not reproduced in Linux.
This must be either a Windows specific issue or the fact that you double click on capabilities. You just need to single click a line.
[EDIT] tested also on Windows. No issue at all (again with a single click)
- fooschnickens
- Real Name: Taylor
That's quite strange. I tested this on a different PC (running Win10 this time and on the latest 4.10.5b build) and got the same behavior modifying the channel capabilities as before.mcallegari wrote:Not reproduced in Linux.
Double-clicking a capability line will allow you to modify and save any changes, single-clicking only moves the line focus in the window without actually switching between the sets of capability values.
I made a quick video to maybe help display the difference in behavior of single and double-clicking within the program:
https://drive.google.com/open?id=0B_Jdz ... 2pKSEVxRk0
