I've created a solo frame with two cue-lists. The second one is just a copy of the first one. I need them to order scenes manually by switching between the two lists, because i can't jump between scenes in one of the lists. In your video this works, on my Mac it doesn't work.
My solutions works fine, but when i selected the same scene in both lists, the result is an blackout.
You can find my file as attachment.
One Scene in two Cue-lists
- Real Name: Michael
- NJK final.qxw
- (495.9 KiB) Downloaded 150 times
- Real Name: David
Thank you for posting your qxw file right away.
Please explain with more precision, because your workspace is quite huge:
- Which actions you perform on your workspace
- Which functions are selected
- What you expect to happen in the fixture monitor
- What happens in the fixture monitor
Thank you
Also, there is a missing fixture definition file when loading your workspace:
No, you have created 2 solo frames, and each solo frame contains one cue list. I think the solo frames play absolutely no role in there, but whatever.MayanBlue wrote:I've created a solo frame with two cue-lists.
Thank you
<Stairville> <LED 56 PAR 64>
Hi Massimo,
Thank you for your answer.
I've made a little Video, where you can see the problem. It's still uploading. As you can see, there are a few problems, when you have the same scenes in 2 frames.
https://www.dropbox.com/s/9z8j3avdrvqah ... m.mp4?dl=0
Please let me know, when i can remove the video file.
Also i attached the missing fixture.
Best regards
Michael
Best regards
Michael
- Stairville-LED-56-PAR-64.qxf
- (2.96 KiB) Downloaded 140 times
Maybe you meant "Hi David" ?
- Real Name: David
I think right now the left and right submasters are setting conflicting intensities to the functions.
I think the right chaser should run copies of the functions in the left chaser (or you can do the opposite, whatever)
If you have a kind of multiple-widgets-per-function virtual console, today QLC+ does not handle this very well.
Perhaps it'll be possible to add an Shortcut and/or Midi Trigger to jump between scenes in a chaser, so there will be no need for 2 chasers. Using the mouse for this isn't a possibility for my setting.
THX
THX
