I can not get QLC+ to control my lighting after updating to Mac OS Sierra 10.12. Below are some details of the situation. I would really appreciate any help that could be provided for trouble shooting.
System:
iMac running macOS Sierra 10.12
QLC+_4.10.4
Enttec DMXUSB Pro
Things to know:
I have run Enttec's Ftdi driver fix and it says there are no Ftdi drivers.
I have tested the USBPRO using Enttecs "PRO-Manager". It recognizes the USBPRO and when I run tests through "PRO-Manager" my lights respond.
Inside QLC+ under "Inputs/Outputs" I can see the DMX USB Pro. If I unplug it, it disappears and if I plug it back in in shows back up. So I feel confident QLC can see my USBPRO.
If I try to create a new function and play around with lights they don't work. If I run one of my existing functions from the Virtual Console it doesn't work. I can't get any lights to do anything through QLC+.
Any ideas?
QLC Not Communicating w/ USB/DMX interface
Use the test version from here: viewtopic.php?f=12&t=3135
I had the same issue using Sierra (Mac OS 10.12.1):
I tried the test version and it seems to works well
So... the question is:
someone is using this test version?
Can I reasonably trust this build and use it in a very simple theatrical play?
(QLC+_4.10.5-TEST-20161030)
TNX for the advice
TNX for the advice
