Hi i have updated yesterday the new version manually from the 20160529, after this i have no working line in.
sound do dmx wold not work, also the led von the usb sound card is not flashing, this is when qlc+ has aces to the usb card
After restore to the older version 20160529 ist works well
Version 20161007 No Line In
What do you mean with "line in" ?
Do you mean sound card line in ?
If so, which soundcard are you using ? (I assume it's USB)
By the way, I haven't changed anything in QLC+ that can compromise the audio input, so this has to be something related to the Debian audio drivers.
Can you please double check the drivers loaded in v20160529 and in v20161007 with the lsmod command ?
If you notice some difference, please post the output here so we can discuss about it and try to resolve it.
- Real Name: Chris
hi, sorry i have not get an mail that you have anser
yes i mean the sound line in:
v20160529
after the installation/update
v20160529
pi@raspberrypi:~ $ lsmod
Module Size Used by
snd_seq_dummy 1269 0
snd_seq 53119 2 snd_seq_dummy
cfg80211 427855 0
rfkill 16037 1 cfg80211
snd_usb_audio 118544 2
snd_hwdep 5727 1 snd_usb_audio
snd_usbmidi_lib 19801 1 snd_usb_audio
snd_rawmidi 18452 1 snd_usbmidi_lib
snd_seq_device 3621 2 snd_seq,snd_rawmidi
spi_bcm2835 7286 0
bcm2835_gpiomem 3040 0
bcm2835_wdt 3225 0
i2c_bcm2708 4770 0
evdev 11396 7
joydev 9024 0
snd_bcm2835 25029 0
snd_pcm 75698 3 snd_bcm2835,snd_usb_audio
snd_timer 19160 3 snd_pcm,snd_seq
snd 51844 12 snd_bcm2835,snd_usb_audio,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_usbmidi_lib,snd_seq_device
uio_pdrv_genirq 3164 0
uio 8000 1 uio_pdrv_genirq
i2c_dev 5859 2
ipv6 347530 48
Module Size Used by
cfg80211 427855 0
snd_usb_audio 118544 0
spi_bcm2835 7286 0
bcm2835_wdt 3225 0
i2c_bcm2708 4770 0
evdev 11396 7
joydev 9024 0
snd_bcm2835 25029 0
snd_pcm 75698 2 snd_bcm2835,snd_usb_audio
snd_timer 19160 2 snd_pcm,snd_seq
snd 51844 10 snd_bcm2835,snd_usb_audio,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_usbmidi_lib,snd_seq_device
i2c_dev 5859 2
ipv6 347530 48
From the lsmod outputs, apprently everything is fine.
There might be an issue with what the Qt libraries detect, but I need to reproduce this on one of my Pis, to eventually fix it.
Please stand by.
Please stand by.
I have finally being able to find the time for this.
I tested with a cheap USB audio card that I have and both audio input and output are working as expected on the latest image.
Are you able to capture a screenshot of the audio devices that QLC+ lists in the Input/Output panel on both images ?
Maybe it's just a question of timings. The boot time now is very fast and maybe your audio card (which is... ?) takes a bit longer to be exposed by linux and QLC+ doesn't detect it when it starts
