Error in Stairville LED Flood 150 definition file
Posted: Sat Oct 08, 2016 9:03 am
by didou64
I found an error in Stairville LED Flood 150 fixture definition.
There is an inversion between depth and height.
Depth is 210 and height is 68 in definition file. See below
<Dimensions Width="260" Depth="210" Height="68" Weight="1.8"/>
Value for depth should be 68 and value for height should be 210. See below screenshot from documentation
LED Flood Panel 150.jpg (3.01 KiB) Viewed 553 times
It is not a big deal but could you fix it as it has an impact in monitor window?
Thank you.
Regards,
Didou
Re: Error in Stairville LED Flood 150 definition file
Posted: Sat Oct 08, 2016 2:42 pm
by Freasy
thanks for spotting it. Here is the corrected file...
Posted: Mon Oct 10, 2016 11:24 pm
by didou64
Many thanks Freasy.
I hope this will be taken into account on next release as this fixture is part of standard library...
Regards,
