Fixture created not recognized
The issues found when using the Fixture Manager panel
dkbales
Real Name: Dale Bales
I have created a fixture for a Chroma-Q CHCS2 with Fixture Definition Editor 4.10.4. I think I did everything correctly but when I bring the fixture into QLC+, I get different properties than what I created the fixture with, i.e., Manufacturer - Generic, Model - Generic, Type - Dimmer. This does not reflect what is in the file I created.
Is there a syntax error that I am missing. I had other issues like the file name when I first started trying to create the file.
Please let me know what I can do to correct this.
Dale Bales
Windows 10 laptop
Small community theater volunteer.
"The theater is small, alas, I am not."
Attach the fixture file
As I can tell you're using windows (next time please add it to your post) so you might need to read where the fixture must be placed in the documentation:
http://www.qlcplus.org/docs/questionsandanswers.html
Namely: the user folder (Q&A 5)
dkbales
The file is in the proper folder.
Massimo,
Here is the file.
I did follow your very useful video tutorial. As I am new to this software and your forums, I apologize for omitting some information. I will update my signature shortly.
Thanks for you help.
Dale
Win10
Chroma-Q-CHCS2.qxf
(2.04 KiB) Downloaded 141 times
Dale Bales
Windows 10 laptop
You haven't added any mode to the definition !
There are 8 DMX modes according to this: http://www.chroma-q.com/support/manuals ... manual.pdf
I have started with a couple of modes, then you can continue that way. Attached.
Chroma-Q-CHCS2.qxf
(3.92 KiB) Downloaded 139 times
dkbales
You are correct. I see that now. I wrote down the information for that and then neglected to enter in the information. I knew it was an error on my part but could not see the foundation for the fault.
Thanks for your help and timely response. This will be one issue I will be sure to double check when creating new fixtures.
:oops:
Dale Bales
Windows 10 laptop
Oh sorry, I edited my previous post. See above
dkbales
I see it now. Thanks!
Dale Bales
Windows 10 laptop
