Haven't used the definition extensively yet, but seems to be working correctly so far.
I wasn't sure how to best get the click and go colors set so they were just roughly matched off of a white ceiling. (My small attempt to algorithmically convert the rgb+amber values in the manual failed miserably.)
The Mega BAR RGBA Manual.
American DJ Mega Bar RGBA
- Real Name: Brian Haskin
- American-DJ-Mega-Bar-RGBA.qxf
- (18.08 KiB) Downloaded 88 times
- Real Name: Robert Box
Use the attached sheet RGBWA to RGB conversion.
Enter the RGB(and W)(and A) values in columns B-F of row 4, the RGB approximations will appear to the right.
For example, W=255, A=255 will generate a washed out amber, without any number going over 255 (as it can't). B=255, A=255 creates a pink colour, as you would expect, since this is basically orange and blue.
A column could also be added to support UV.
