My bad this has been frustrating
[mcallegari] The original post has been edited by the author and the contents deleted. User warned this is a bad behaviour for the forum.
enttec usb open device not working on OSX 10.9 or 10.11 works in windows
- Real Name: travis
I don't think that with your approach you will get any help in this forum.
"my diy interface" means nothing. Where does it come from ? What does it clone ? What are the USB VID/PID ? Does it mount a FTDI chip ?
And as you point your finger toward QLC+, here's the proof you're wrong, and that you probably need to understand how your Mac works.
I am using OSX 10.11.4
ENTTEC DMX USB Pro MK2, Apple driver enabled: ENTTEC DMX USB Open clone, Apple driver disabled:
i need to help (if is possible will be better speak in italian or spanish for me ).
I work wit OS X yosemite and enttec open dmx.
But i can't work (no signal dmx).. i read a lot of forum about that (ftdi, d2xx etc.) but really i don't know where i make mistake.
Someone can help me in italian please?
- Real Name: Michele
hi
i have same problem.
I buy OPENDMX USB Enttec, I use QLC+ on Microsoft 7 anx XP and on MAcbook Pro 10.11.6.
On Microsoft i have DMX signal.
On Apple i haven't DMX signal, but on QLC+ interface and manager the usb device is visible and is possible to select.
I try all instructions that i found on forum and faq ( Qlc+ and Enttec ), but is impossible to use.
Some solutions??
Some solutions??
hi
there is a news...
I try to use Lightkey for test my mac with Enttec.... and work .
If i use before Lightkey, close Lightkey, and after i open QLC+ ..... work regolary.
If i reebot my mac, and open directly QLC+ ....don't work......close QLC+....open Lightkey....close Lightkey ....open QLC+.....work!!!
Some answer?!
Michele
there is a news...
Some answer?!
Michele
- Real Name: micha
i have the same problem with my enttec USB Assembled Widget.
the solution above works for me, looks like it is a permission problem. While Ligthkey asks for Administrator permissions qlc+ does not. I tried to work as admin which i normally do not but the problem is the same.
- Real Name: Laurent Launay
I also have the same issue as you on any current macOS systems (El Capitan as well as Sierra).
Let me suggest you the same thing that Massimo also suggested me: try the 'in development' version: viewtopic.php?f=12&t=3135
It works well for me.
Best!
Laurent
Best!
Laurent
- Real Name: philippe GATT
I have about the same problem whatever the version of the software interface is recognized but it has no active DATA signal.
Config:
USB DMX ENTTENC OPENDMX 512 CANEAUX
MACBOOK PRO
core 2 duo 2,53ghz 8go DDR 3
OSX ELCAPITAN 10.11.6
Config:
MACBOOK PRO
