Just wanted to make a post showing an issue I've encountered while setting the heads for my fixtures. It looks as if when I set the head to red green blue and also dimmer the channels associated with those functions are one channel less than they should be. So if my American DJ Inno pocket wash on 19 channel mode has the channel 12 dimmer checked. When I exit out of the window and look at the channels values under the head tab. The channels are one less than I had set them for.
I appreciate everyone that puts any amount of work into this forum and the software itself. You light the way for me and my band. So thankful
Possible bug with creation of heads in fixture definition editor
Good catch! I've fixed it in git.
Git is a program for managing source code. For you it means that it will be fixed in the next version.
