Hi there,
I think there is a bug when the "can fade" option is unchecked on fixtures. When I have a fixture's "can fade" setting off I can turn the fixture on with a scene, but cannot turn it off (using a solo frame with buttons).
Is this intended? I had thought unchecking "can fade" just made the channel snap to the final value instead of fading with other fixtures.
Steps to reproduce:
1. Open provided workspace file
2. Go to Virtual Console
3. Open monitor so you can see output
4. Switch to operate mode
5. Press the "on" button or "1 on, 2 off" button
6. Press the "off" button. Notice the fixture(s) don't turn off.
I am running QLC+ version 4.10.4
Thank you
Can Fade Preventing Fixtures Being Able to Turn Off
- Real Name: James
- Can fade bug.qxw
- (4.29 KiB) Downloaded 267 times
- Real Name: James Lo
I am seeing similar issues with QLC+ 4.10.4 on both Windows 7 and OS X 10.10.5 with Enttec Open DMX USB.
Here are the steps to reproduce:
- Create a generic fixture
- Create 2 scenes, one to set the intensity to 255, and another to set the intensity to 0
- Test that your fixture turns on and off when you click the corresponding scene
- Create a chaser with the two scenes you previously created, and set the common hold time to 1 sec
- Preview your chaser to see that the fixture turns on and off
- View the corresponding fader going up and down in Simple Desk
- Stop the preview
- Now edit your fixture’s fade behavior to exclude intensity
- Select the first step in your chaser and run the preview again. Note that your fixture turns on and stays on.
- Note that the corresponding fader in Simple Desk no longer moves
- Stop the preview
- Try clicking the scenes and note that the fixture is stuck on
- Try the fader in Simple Desk and note that the fixture does not respond
- Save your workspace and quit QLC+
- Reopen your workspace and note that the fixture turns off
