hello,
I use a lot qlc+ in my work in theatre conditions.
I use a lot cue list and show manager to manage the sound and the light of my shows.
I'm really happy that you add the possibliy of play/pause. is the great improvement in theatre condition (particulary during repetitions).
I test it but It don't work for me when try it with sound.
my configuration:
ubuntu 14.04
I tried with a show with a music inside.
I tried with wav, mp3 and ogg files but don't change my problem.
when I play a sound in the show manager I receive this message in the terminal:
ALSA lib pcm_hw.c:1667:(_snd_pcm_hw_open) Invalid value for card
but continue the sound and qlc+ continue to run without problem.
when if I click on "pause" the show and the music pause but when if after I click on "play" the sound play but qlc+ freeze with no message in the terminal.
I need to kill qlcplus the the sound stop.
I tried with different files but happen everytime this problem.
I notice too that when I try to preview left, right or both channel it don't draw the image.
I hope I write this message in the right place in this forum.
thank's again for this great software.
yan
problems with Play/Pause with sounds
Are you hitting pause from the Show Manager or from a VC Cue List on a Show step ?
That's a big difference in the code.
- Real Name: bernard yan
thank's very much for your answer.
I encounter the problem in the Show Manager and from a VC Cue List on a Show step.
in show manager:
when I hit pause the the music stop and the display time stop too. but when after I hit play the music restart but the time the display time don't continue. the time displayed is the time when I hitted pause and qlc+ freeze but the sound continue playing until a kill qlc+.
in cue list (with a chaser containing only one step with show inside):
I encounter exactly the same problem with diplay time freeze too and the mucic continue pplaying when qlc+ freeze.
I join you the qlc file wich I used to test pause.
thanks very much...
in show manager:
thanks very much...
- test_pause.qxw
- (2.37 KiB) Downloaded 128 times
I think I got it.
I tested on my PC and it works. I suspect the difference is definitely going to be the Qt version.
The QLC+ released packages are still inked to Qt 4, which is pretty old now, while I always test with Qt5.
I will check with Qt4, but in the meantime, can you please test with a OBS version instead ?
Downloads here: https://software.opensuse.org/download. ... lcplus-qt5
Update: I found an fixed the issue. It was definitely related to Qt4, which uses a direct ALSA implementation to play audio files.
It's now fixed on GIT, and OBS GIT version are currently being built.
I installed GIT Qt4 (debug) version. Q Light Controller Plus version 4.10.5 GIT
and it's work for me . pause is working
I continue testing this new function and I found some other problems.
in operate mode when if I hit pause (in cue list) during a show step and I stop the operate mode -> qlc+ freeze.
this problem happen only if the step is paused when I hit stop operate icon.
if the step is playing when I hit stop operate icon no problem.
In show manager a similar problem:
if I play a show and I pause, then I hit operate mode and I go back in edit mode -> qlc+ freeze.
just to say: play / pause is really a great improvement. really usefull.
thank's very much.
thank's very much.
