[HEADS UP] Help needed to test incoming version 4.10.0
- Real Name: Daniel
It does not depend on the pattern as far as I can see, but it depends on the current y position and affects the x movement component only, as far as I could figure out the effect is stronger the greater the distance from y=127.
Example workspace:
Example workspace:
Hi all,
I just built the latest 4.10.0 source from git on an RPi2 and tried to send some DMX data over my DMX4ALL USB Interface.
The interface itself seems to work (/dev/ttyUSB0 found, using a terminal I'm able to query some information and even under Win32 it works), but I fail to produce any DMX data using QLC+ (and even olad).
Plugin: DMX USB
Device "1: DMX4ALL PC USB INTERFACE"
Output: CHECK
Status says:
Device is operating correctly.
Driver in use: libFTDI
Protocol: DMX4ALL DMX-USB (Output)
Manufacturer: DMX4ALL
I also tried to start qlc+ as root, but the result was a blank application-window. I'm also not able to increase debugging information running qlcplus --debug 3 or --debug=3. I also tried to unload the ftdi-serial module, the ttyUSB0-device disappeared but the issue is still the same.
Is there an issue with the current code or I'm doing anything wrong?
regards
Plugin: DMX USB
Output: CHECK
Status says:
regards
No. I just built the GIT sources and tested on my RPi image with a DMX4ALL Stageprofi Mk2 device. All works fine.joky wrote:I just built the latest 4.10.0 source from git on an RPi2 and tried to send some DMX data over my DMX4ALL USB Interface.
You're probably messing up with user permissions so they cannot access /dev/ttyUSB.
By the way, since this is not the right place to discuss custom builds or the RPi, please open a separate thread in case (in the RPi forum)
- sbenejam
I tested on my system compiled yesterday with create-deb.sh no errors creating deb package. I tested old projects and all seems to work fine. My USB devices Enttec DMX USB Pro, Digitus DA-70157 USB RS-485 adapter and NanoKontrol2 are correctly detected and seems to work fine too (not tested with real fixtures connected).
My computer runs Ubuntu 15.04 with qlcplus compiled with Qt5.
- Real Name: Derek
One minor cosmetic fault, which I think is in 4.9.1 as well.
On the Channel Properties Configuration page, selecting LTP or HTP leaves the selection box on screen. You have to move the page to see the other options, but the selection box stays where it is, floating on screen.
Using Linux Mint 17.02 Rafaella (based on Ubuntu 14.04 ?)
(Must be fairly unique to me, as others have used ltp etc and not mentioned it.)
I use Mint 17.2 and I don't experience that behaviour. Are you using QLC+ on Qt4 or Qt5 ?Deece wrote:One minor cosmetic fault, which I think is in 4.9.1 as well.
Are you using weird Intel drivers or weird Mesa versions ?
I use a GIT version of Mesa and I experience a damn refresh issue on Chrome (similar to what you see) but no issue in QLC+
- Real Name: Derek
I use a GIT version of Mesa and I experience a damn refresh issue on Chrome (similar to what you see) but no issue in QLC+[/quote]
QT4. Not using anything strange that I know of. Nvidia 340.93
All other selectors work fine, just the ltp/htp .
I'll try to compile my own version..rather than a deb.
- Real Name: Florian
I just tested some adapters on OS X:
- The DMX4All StageProfi Mk2 still works.
- The DMX4All NanoDMX works, too. Thanks for that!
- But the Eurolite DMX512-Pro does not work. It is recognized, but I can't get any output.
- It doesn't work to use more than one adapter. If I connect two of them, both are recognized. But as soon as I try to set the checkbox for the second universe I get the error message "An error occurred during opening the device". (And no output, of course.)
(All tests are made on a Mac with Yosemite, tried both with the Apple's own FTDI driver enabled and disabled)
The Eurolite should work in OSX only if the driver in use is "QtSerialPort". Is that your case ?Flo wrote:But the Eurolite DMX512-Pro does not work. It is recognized, but I can't get any output.
Unfortunately I don't have the device, so I mostly copied the sequence I used for the NanoDMX.
More details please. Which adapters did you try to use together and which driver were you using ? (libFTDI or QtSerialPort)Flo wrote:It doesn't work to use more than one adapter. If I connect two of them, both are recognized. But as soon as I try to set the checkbox for the second universe I get the error message "An error occurred during opening the device". (And no output, of course.)
The Arch repository seems to be online, so if it worked with qlcplus-qt4, it should work with -git version too. (the files are in the same place)debbio wrote:On archlinux x64 with ENTTEC Mk2, qlcplus-qt4 works without problem.. Adding your repository and trying the version qlcplus-qt4-git I receive a 404 error on the server, no problem with qlcplus-qt4
Can you please post the complete error message ? Maybe the URL causing 404 is just wrong.
Yes: "Driver in use: QtSerialPort"mcallegari wrote:The Eurolite should work in OSX only if the driver in use is "QtSerialPort". Is that your case ?Flo wrote:But the Eurolite DMX512-Pro does not work. It is recognized, but I can't get any output.
One thing to mention: QLC+ doesn't seem to automatically set the right protocol mode for the adapters. I have to manually switch it between "DMX4All" and "Eurolite" in the settings.
I tried the combinations StageProfi+NanoDMX and NanoDMX+Eurolite. All of them use the QtSerialPort driver. How do I activate the libFTDI driver?mcallegari wrote:More details please. Which adapters did you try to use together and which driver were you using ? (libFTDI or QtSerialPort)Flo wrote:It doesn't work to use more than one adapter. If I connect two of them, both are recognized. But as soon as I try to set the checkbox for the second universe I get the error message "An error occurred during opening the device". (And no output, of course.)
Are there plans to enable the two new adapters on Windows, too? And, BTW: The new feature to reset single channels in the simple desk is great! I missed that a lot.
I just found another little bug:
I manually set the channels per page of the simple desk to 30 (because 32 are too wide for my MacBook). Now I can't reach the last two channels (511 and 512) because after page 17 QLC+ directly jumps back to 1.
Fixed in git.Flo wrote:I just found another little bug:
Here it is the error code on archlinux:
:: Vuoi procedere con l'installazione? [S/n] s
:: Download dei pacchetti in corso...
errore: impossibile scaricare il pacchetto 'qlcplus-qt4-git-4.10.0.20150929.063005b-0-x86_64.pkg.tar.xz' da download.opensuse.org : The requested URL returned error: 404
attenzione: impossibile scaricare alcuni file
errore: impossibile eseguire l'operazione richiesta (errore inaspettato)
Si sono verificati degli errori, nessun pacchetto è stato aggiornato.
Got it. You're trying to download a version that's not on the server anymore.debbio wrote:Here it is the error code on archlinux:Code: Select all
See here: http://download.opensuse.org/repositori ... ra/x86_64/
Being GIT versions, I retrigger the build every few days, so you should update your packages list before trying to install a GIT version.
Now I have no idea how this is done on Arch. On Ubuntu it is something like "apt-get update"
In theory you should never touch the protocol mapping. Can you please delete your QLC+ preference file and start from scratch ?Flo wrote:One thing to mention: QLC+ doesn't seem to automatically set the right protocol mode for the adapters. I have to manually switch it between "DMX4All" and "Eurolite" in the settings.
You actually found a monster bug. It was there in 4.9.x too. It's fixed now on GIT.Flo wrote:I tried the combinations StageProfi+NanoDMX and NanoDMX+Eurolite. All of them use the QtSerialPort driver.
In OSX, just disable the Apple driver and all the adapters should be detected by libFTDI.Flo wrote:How do I activate the libFTDI driver?
No. Windows works with drivers and each adapter must have its own. With FTDI adapters it's easy cause there is a documented SDK to use them.Flo wrote:Are there plans to enable the two new adapters on Windows, too?
NanoDMX and Eurolite don't use FTDI chips, so I suppose they have their own drivers and I'm not planning to support them.
