yes for that all good)
found new bug
when we use audio triger, for dmx value per volume, it`s not allowd to use slider on same dmx function, it`s all time at 0 value
QLC+ TEST versions
- lorenzoandreani
- Real Name: Lorenzo Andreani
QLC+_4.11.1.162.exe on Windows 10 (1703) Pro
Sequence Copy Error:
- Add two Generic RGB named "Generic RGB #1" and "Generic RGB #2"
- Add one sequence named "Sequence #1" and create a simple sequence for "Generic RGB #1" (for example two scene: white and black on loop)
- In VC add one button and link it to "Sequence #1" and test it
- Ok: the "Generic RGB #1" turn on and off
- Now create a copy of "Sequence #1" so you'll have "Sequence #1 (Copy)"
- Edit "Sequence #1 (Copy)": Remove "Generic RGB #1" and add "Generic RGB #2"
- Edit "Sequence #1 (Copy)": edit the two scene to create a simple sequence for "Generic RGB #2" (for example two scene: blue and red on loop)
- In VC add another Button and link it to "Sequence #1 (Copy)" and test it
- Not Ok: "Generic RGB #2" blink blue and red but also "Generic RGB #1" blink
I think the problem is due to the fact that the "Sequence #1 (Copy)" remains connected to the scene of "Sequence #1"
P.S.: Now the sequences have two names "Chaser name" and "Scene name".
In my opinion, the "Scene name" field no longer has utility and should be compiled automatically with the same value as the "Chaser name" field.
- Sequence.qxw
- (3.89 KiB) Downloaded 2746 times
@lorenzoandreani: I had similar Problems in the latest Full-Version (4.11.0) when using copys and copys of copys. Sometimes when i edit copys of copys it changes things in the original and first copy too.
After a week of work you make the last show and using sequences or scenes from another show as copy from an copy. You change a view little things for new show, but after that the shows you made in past are broken now, because editing a copy change things in the original.
I still think the Problem is, that copys are not independent from the original, because all copys are bound to a hidden scene. Look at your Save File (is xml Format):
and later the copy
Both are bound to Scene "0" (BoundScene="0"). When you look at Scene 0:
Some things like used Fixtures are saved in this hidden Scene, not in the sequence itself. Changing things (for example the fixture val) in the original (Sequence #1) change this information in the copy (Sequence #1 (Copy)) too, because it will chanced in the hidden scene, on that both sequences (Sequence #1 and the copy) bound to. The copy of a Squence is not independent from its original! I think this cause the problems you descriped and i had too!
I think a better way it is to stop using bindings and store all informations in The Sequence itself like this:
Imagine you make a copy of a file in windows and after deleting the copy the original is deleted too - It make no sence for me to bound copys or copys of copys to anything. All should be independent from another, so you avoid problems!
Hope my informations can help...
Greetings from Germany
<Function ID="1" Type="Sequence" Name="Sequence #1" BoundScene="0">
<Function ID="2" Type="Sequence" Name="Sequence #1 (Copy)" BoundScene="0">
<Function ID="0" Type="Scene" Name="Sequence #1" Hidden="True">
<Speed FadeIn="0" FadeOut="0" Duration="0"/>
<FixtureVal ID="1">0,0,1,0,2,0</FixtureVal>
<FixtureVal ID="0">0,0,1,0,2,0</FixtureVal>
</Function>
<Function ID="1" Type="Sequence" Name="Sequence #1">
other informations...
</Function>
- lorenzoandreani
From a few days, when I download the Windows .exe test version (https://dl.bintray.com/mcallegari/qlcplus/) Windows Defender blocks it indicating that it contains a Trojan:Win32/Spursint.F!cl virus
Does it only happen to me?
I only see my AVG inspecting the .exe for quite some time before letting me work with it ... so yes maybe there is something inside that might have some kind of false-positive signature present...
Test builds are produced by an online service (AppVeyor) running on virtual machines. I really doubt that's contamined with viruses.
I suspect instead this is once again a proof that Windows (and related apps) don't really like software built outside their world. They expect everyone to use MSVC, .NET frameworks and other packaging tools. Well, this is not the case for QLC+. I use all free & open source tools.
- lorenzoandreani
Yes, I think you're rightmcallegari wrote: ↑Mon Dec 10, 2018 1:02 pm I suspect instead this is once again a proof that Windows (and related apps) don't really like software built outside their world. They expect everyone to use MSVC, .NET frameworks and other packaging tools. Well, this is not the case for QLC+. I use all free & open source tools.
- Real Name: Iro Suraci
4.12.1.77 and above can not to be dawnloaded 'couse Chrome report a virus inside the .exe file
EDIT: sorry for double post I didn't read above)
BTW I'm not happy about remove of separated faders for cue list widget in the last build i tested 4.12.1.83...I personally disagee.
There's been a poll for that: viewtopic.php?f=17&t=12887maximortal wrote: ↑Thu Dec 20, 2018 10:57 am BTW I'm not happy about remove of separated faders for cue list widget in the last build i tested 4.12.1.83...I personally disagee.
Where were you ? Where is your "no" vote and the explanation of your usage case requiring 2 faders ?
Complaining now is useless.
I was busy at work, not you fault off course.
now I'm a bit more free and I'm testing new versions and so on
btw TEST ar to be tested so I supposed (wrongly as it appears) that wasn't a definitive change
I want test the latest build but in https://software.opensuse.org/download. ... us-qt5-git all the version are 4.12.1.20181216 and 4.12.1.20181111 for archlinux.
Arch builds should be fixed nownozof wrote: ↑Fri Dec 21, 2018 10:10 am I want test the latest build but in https://software.opensuse.org/download. ... us-qt5-git all the version are 4.12.1.20181216 and 4.12.1.20181111 for archlinux.
- Real Name: philippe GATT
Whatever version 4.12 the module controls plant and does not open.
Macbook pro Core 2 duo 2,53 Ghz 8 Go DDR 3
- lorenzoandreani
Windows 10
QLC+_4.12.2.30.exe
Artnet Fixture in LTP mode:
- a button linked to scene set the channel 1 to 255
- a Slider in Level Mode is linked to channel 1
- in Live Mode slider work
- Activate the Button (so the channel 1 go to 255)
- But slider does not work anymore
QLC+_4.12.2.30.exe
- ArtNet.qxw
- (4.16 KiB) Downloaded 2094 times
- edogawa
- Real Name: Edgar Aichinger
I'm not Massimo, but the initial post of this thread has all the links for test versions, and even tells the date for the Windows build:
Looking at the version numbers of the filenames in that linked page, it seems obvious what the latest version is, 4.12.4.158
Windows: Automated builds (updated: 2021-02-26)
