Error initialization Peperoni lights's USBDMX-xswitch
tolmino
After last Git update it works Great !!!!
No delay
and no auto movements
and in debug there are not broken pipe!!!
Thanks Massimo !!!!
tolmino
.... i have re-connected rodin1 to that pc.
and the problem now i have on it:
while xswitch give a correctly output, rodin1 don't move nothing (give a dmx signal found by moving head).
i have made 2 debug files that attach here
Massimo Callegari
Very weird. Jan just added the support for newer firmwares ( > 0x600) but the previous code hasn't been touched.
My Rodin1 works fine but I've got a 0x60x firmware. Maybe you can upgrade yours too ?
tolmino
Hi Massimo, i attach new debug files obtained after last git upgrade....
all my peperoni interfaces are freezing after some movements or some inputs....
and when freeze, their led are not blinking or are blinking in a different way
when i have used only rodin1 in output, all was working well ...
Jan hasn't sent me new firmware too. he asked me if it is necessary.
Massimo Callegari
Tolmino, excuse me but I'm getting lost with all this information you're posting.
I don't understand the setup you're using for each test and I don't have time to guess it from the debug logs.
So, please:
- open a new topic as this is not related anymore to X-Switch not being recognized
- for each debug log note which device/s connected, which settings (input/output) and all the info that can help
Note also that input and output at the same time is allowed but not supported. It seems to be the case of debug.rodin1
