American DJ-Inno Spot Pro
Massimo Callegari
[Originally posted by Marcus]
Hi All,
I'm new to Q Light Controller Plus and was wondering if someone can help me with a fixture file for the American DJ Inno Spot PRO. The manual can be found at http://adjmedia.s3-website-eu-west-1.am ... %20Pro.pdf
I hope someone can help.
Have a great day!
Marcus.
Massimo Callegari
Here's the fixture provided by RODOLFO
American%20DJ-Inno%20Spot%20Pro.qxf
(6.26 KiB) Downloaded 205 times
Massimo Callegari
Rodolfo, physical information and power consumption are missing.
Also, if you are grabbing fixtures from the Avolites D4 Personalities library, please don't ! They're covered by Avolites copyrights.
RODOLFO
ok update done
I actually uses the information D'avolite, Hog, grandMA 2 Sunlite and documentation to bring me as close to the device.
Best Regards
Massimo Callegari
Rodolfo, I reveiewed this fixture. Please follow the manual and don't invent things.
- as already asked, for "Open gobo" use others/gobo0022
- shutter channel:
- wrong interval 0-7 that you called "Closed" while in the manual is called "blackout"
- interval 140-181, again invented name
- interval 182-189, completely missing
- interval 190-231, invented name
- interval 248-255, wrong (you did 255-255)
- channel 13: invented name. It's "Movement speed" and not "P/T Speed"
- channel 14: invented name. It's "Blackout/Reset" and not "Control"
You know, it shouldn't take this much to review a fixture. I shouldn't go this deep because lots of mistakes.
Do not rush to post a new fixture online. This is not a race and you don't win a medal.
Please take your time and be more accurate with what the manuals say.
Thanks you
Boxy
Hi guys,
Try this. I've removed the gobos altogether as there are none that completely match. For example, there is no cobweb which the included gobo clearly is. I don't have time to create images at the moment.
(6.38 KiB) Downloaded 193 times
Massimo Callegari
Boxy, I just committed my reviewed version
https://github.com/mcallegari/qlcplus/b ... ot-Pro.qxf
And this made me realize that even the file name is wrong ! Gonna fix it.
(6.56 KiB) Downloaded 180 times
Boxy
Ha ha! Version control...
