I just tested the new image and got this:
pi@qlcplus:~ $ sudo qlcplus service status
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
Aborted
hdmi_force_hotplug=1 does not seem to work in bookworm
as soon as I plug in a monitor it continues to start
display error back again?
Thanks for reporting.
Unfortunately I can confirm this is back (damnit!)
I haven't tried it yet, but maybe using another platform plugin will help.
Edit
and replace
with
or
If anyone tries before me, please report if it works
Edit
/usr/sbin/qlcplus-start.sh
-platform eglfs
-platform offscreen
-platform linuxfb
Great, thank you.
At least we have a workaround while we wait for an official solution from the RPi foundation devs.
- Real Name: Gareth
Hi
I have run into the same error - now getting the same message from the qlcplus service call.
I have implemented the change above, and this seems to resolve the problem, I now get the Web Page, but im not confident I have implemented the change correctly, and won't run into other problems down the line because of it.
Could someone more knowledgeable please check what I have done
My Original file looked like this (with the comments out at the beginning removed)
And my modified (now working) file looks like this
Could someone please confirm if this is the correct way to change the file n- or should I have left more uncommented - especially the parameters on the first line.
thanks
Gareth
QLCPLUS_OPTS="-platform eglfs --nowm --web --web-auth --operate --overscan"
if [ ! -f $HOME/.qlcplus/eglfs.json ]; then
mkdir -p $HOME/.qlcplus
echo '{ "device": "/dev/dri/card1" }' > $HOME/.qlcplus/eglfs.json
fi
if [ -f $HOME/.qlcplus/autostart.qxw ]; then
QLCPLUS_OPTS="$QLCPLUS_OPTS --open $HOME/.qlcplus/autostart.qxw"
fi
# if NTP hasn't done its job already, set the date to modern age...
CURRDATE=`date +%Y`
if [ "$CURRDATE" -lt "2024" ]; then
date +%Y%m%d -s "20240313"
fi
export QT_QPA_EGLFS_PHYSICAL_WIDTH=320
export QT_QPA_EGLFS_PHYSICAL_HEIGHT=200
export QT_QPA_EGLFS_ALWAYS_SET_MODE=1
export QT_QPA_EGLFS_KMS_CONFIG=$HOME/.qlcplus/eglfs.json
/usr/bin/qlcplus $QLCPLUS_OPTS
QLCPLUS_OPTS="-platform offscreen"
#eglfs --nowm --web --web-auth --operate --overscan"
#if [ ! -f $HOME/.qlcplus/eglfs.json ]; then
# mkdir -p $HOME/.qlcplus
# echo '{ "device": "/dev/dri/card1" }' > $HOME/.qlcplus/eglfs.json
#fi
#if [ -f $HOME/.qlcplus/autostart.qxw ]; then
# QLCPLUS_OPTS="$QLCPLUS_OPTS --open $HOME/.qlcplus/autostart.qxw"
#fi
CURRDATE=`date +%Y`
fi
#export QT_QPA_EGLFS_PHYSICAL_WIDTH=320
#export QT_QPA_EGLFS_PHYSICAL_HEIGHT=200
#export QT_QPA_EGLFS_ALWAYS_SET_MODE=1
#export QT_QPA_EGLFS_KMS_CONFIG=$HOME/.qlcplus/eglfs.json
thanks
Gareth
No, the first line should look like this:
QLCPLUS_OPTS="-platform offscreen --nowm --web --web-auth --operate --overscan"
- Real Name: Chad Bishop
Moving from Ubuntu 22.04 to 24.04 and from qlcplus 4.12.4 to 4.12.7 yielded us an error with a log entry like this :
After a bit of experimentation these changes in our custom systemd qlcplus.service got us over the top :May 02 23:21:24 ohbc-lighting systemd[1]: Started qlcplus.service - Oak Hills Baptist Church Lighting Controller.
May 02 23:21:45 ohbc-lighting qlcplus[2471]: Authorization required, but no authorization protocol specified
May 02 23:21:45 ohbc-lighting qlcplus[2471]: qt.qpa.xcb: could not connect to display :0
May 02 23:21:45 ohbc-lighting qlcplus[2471]: qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
May 02 23:21:45 ohbc-lighting qlcplus[2471]: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
May 02 23:21:45 ohbc-lighting qlcplus[2471]: Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
May 02 23:22:11 ohbc-lighting systemd[1]: qlcplus.service: Main process exited, code=dumped, status=6/ABRT
May 02 23:22:11 ohbc-lighting systemd[1]: qlcplus.service: Failed with result 'core-dump'.
[Service]
Type=idle
-Environment=DISPLAY=:0
+Environment="QT_QPA_PLATFORM=wayland"
+Environment="XDG_RUNTIME_DIR=/run/user/1000"
