Hi to all!
I have been using QLC+ for some years now and so far i worked out how to use it most of the times.
For a school play in march I am preparing new light fixtures, remapping existing scenes and I also downloaded the latest version of QLC+.
But right now i am stuck:
I noticed that the new fixtures don't turn on when they are supposed to. They are RGB-LEDs and part of RGB-matrix.
They have a separate dimmer channel but in the old version, there was the feature to always have the dimmer of a fixture go to 100% if it is in use as part of the RGB matrix.
But this option went missing. It still shows up on some old files but disappears if I deselect it and it doesn't some to work anymore anyways.
What happened here? Am I doing something wrong?
Thank you for your support!
"Other Controls - Dimmer Control" missing in RGB Matrix
The intensity channel got separated from the RGB-matrix some versions ago.
You now can use the RGB matrix only to control intensity levels in the present version.
For your case, I'd put a slider on your VC, set it to level control and using this slider to set the intensity.
- Real Name: Jakob
Thank you so much for your quick reply!
OK, so I will probably make a collection with the RGB-matrix and the dimmer level for the show.
But if I understand it correctly, while creating a RGB-matrix there is no way for a "run preview" (the play-button in the matrix configuration) with the actual lights?
Or is there a workaround for this usecase as well?
- Real Name: Jakob
That is a great idea! Of course it would be nice to have a simple button for that (Like "Set all dimmer channels to 100%") but at least this way it is possible to have a "live preview" while adjusting the settings! Thanks a bunch!
- Real Name: Thomas Tippl
Hey guys,
you saved my day. Thank you very much for the idea to make a collection. I didn't know that this functions even exists.
It makes some other cool thing possible. So it is really easy to combine a RGB effect with the dimmer of the rgbw or others that have a separate dimmer channel for the intensity.
regards
regards
