Eurolite LED PIX-16 QCL Bar
Foul
Real Name: Cédric Monféfoul
I am in the process of entering the different channels with the editor... but the 64 Chans is giving me problems.
Each channel controls a color... but the colors repeat and cannot be combined in the editor:
ex :
Channel 1 / value 000-255 / Red 0-100%
Channel 2 / value 000-255 / Green 0-100%
Channel 3 / value 000-255 / Blue 0-100%
Channel 4 / value 000-255 / White 0-100%
Channel 5 / value 000-255 / Red 0-100%
Channel 6 / value 000-255 / Green 0-100%
Channel 64 / value 000-255 / White 0-100%
In the editor, I can only choose a color once... and yet they appear several times.
How to do ??? create multiple channels for the same color???
THANKS.
EDIT : OK NOW
Eurolite LED PIX-16 QCL Bar.pdf
(973.74 KiB) Downloaded 7 times
Eurolite-LED-PIX-16-QCL-Bar.qxf
(20.81 KiB) Downloaded 5 times
MichelSliepenbeek
Real Name: Michel Sliepenbeek
Have a look at the Fixture definition of the Eurolite Led DMX Pixell Tube 16 RGB or the Showtec LED Light BAr 16.
Just make a copy, rename it and add the White channels.
Or start with a copy of the Showtec Led Pixel Bar 12 RGBW and add 4 more "pixels".
Last edited by MichelSliepenbeek on Tue Mar 12, 2024 8:04 pm, edited 1 time in total.
Foul
So the solution is 1 color per chan.. Ok ;)
MichelSliepenbeek
Don't forget to define "the Heads".
Foul
Must be ok now ! thx !
Need to Validate by admin
