Hello
I have setup QLC with TouchOSC and works fine. The problem is when I open Traktor to play music. It sends the midi messages and conflict with Traktor
Is there any way to avoid that ??
QLC Connected with TouchOSC makes conflicts to Traktor
- sbenejam
TouchOSC can send OSC and Midi. If you connect TouchOSC with QLC+ via OSC you can deactivate Midi output in TouchOSC.
- sbenejam
This is explained in the TouchOSC online manual.
https://hexler.net/touchosc/manual/connections-midi
https://hexler.net/touchosc/manual/connections-osc
You have not indicated which operating system you are using. I am using Ubuntu 22.04 and I can connect or disconnect midi ports at will if for whatever reason they have automatically connected or by mistake with a program to which it would not have to be connected.
